You can buy loom adaptors for this Kallen. Well for my older GU i could... I would assume its the same for the later U's.
I could not find a adapter loom from my last 2 stereos. So just bought a Nissan to "anything " adapter and soldered the other end to the small stereo loom/ plug . That way the car harness stays untouched .
Tapatalked from S6
Sorry to hijack rocket, maybe you can help..
My 08 stock stereo has 3 plugs on the back.. the main 2 which obviously control the bulk of the radio..
But the 3rd goes to the bottom corner..
wires are black. Light green and purple.
As you can see the aerpro does not connect to it?? Any idea what it is??
And just my luck the jvc plug is a mini so the aerpro doesn't fit.
So hodge..
I'm guessing most the colors are standard on the aerpro?
My unit has a separate reverse wire and park light switch..
Would they be the missing wires on the 3rd plug??
