Results 21 to 30 of 41
Thread: Show us your other toys
    Advanced onemadgq's Avatar
    Sep 2015
    Tasmania
    Hi David here are some of my other ridesdonalds 009.jpgIMAG2373.jpgIMAG3846.jpgIMAG3846.jpg
  2. #22
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Mate you would fit in well over here in Millparkistan. Do you wear you cap backwards, have the doof doof up loud and recline the drivers seat so far your looking out the rear window? If so you'd be a local here. And the go snails pace, on an angle over speed humps here too. Drives me nuts i just wanna run them over.
    HAHAHA
    2002 GU wagon 3.0lt , auto , piranha dual batteries , 3" lift , chip , needle & Dawes valves - just gettin started
  3. #23
    Patrol Guru Rocket55's Avatar
    Sydney
    Cheers Rod
    My Build 2005 TD42TI
  4. #24
    Jan 2014
    Shepparton VIC
    So in theory I could use this type of setup for activate sprinklers 2 help defend my house should there be a bush fire while I'm not at home?
    What sort of cost would be involved?
    Certainly you can, but you have to remember with any system there's a risk involved (including the system not working when required) and it will be high on homemade systems.
    Cost wise around $100 for the controller only, you will need sprinklers and other things.
    You may need a Raspberry Pi, as mine is connected to HP Microserver, Internet and powersupply.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  5. The Following User Says Thank You to MyGU8 For This Useful Post:
    NissanGQ4.2 (19th January 2016)
  6. #25
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Do not rely on anything electrical to help fight a fire as power is the first thing to go out
  7. The Following 3 Users Say Thank You to Kimbo63 For This Useful Post:
    BigRAWesty (20th January 2016), NissanGQ4.2 (19th January 2016), Winnie (19th January 2016)
  8. #26
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Oh yeah ofcourse that's exactly what I do, that's the only thing a street car owner does. But when I'm in my patrol I fit in better over here where there isn't as many townie 4wd owners that spend more time buying parts and talking about their cars than driving them. Drives me nuts and I just want to throw mud at them.
    >>>tappin from tassie
    Hello from Under Down Under!
  9. #27
    Aug 2011
    North West Tas
    56 Post(s)
    Done that before when a bush fire was travel past quickly about 1.5k's away! Didn't want it 2 burn my beer!!!!!!
    Ohhhhh we talking bush fires? I was talking about my zucchinis
    >>>tappin from tassie
  10. The Following 2 Users Say Thank You to taslucas For This Useful Post:
  11. #28
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Kimbo63 View Post
    Thanks, I'm already aware of that and was more looking at a defense if I was not home and could activate if before power or mobile reception was lost.
  12. #29
    Jan 2014
    Shepparton VIC
    You can do so many things with Arduino. Most of them even can be operated without main power (i.e. only battery operated).
    If you consider something is better than nothing, then in addition to internet connected system, it can be configured as a standalone system where you can plant some sensors around your house to trigger the sprinklers automatically - without your intervention.
    In general micro-controllers are very reliable compare to computer systems (Micro processors), but again mine is only a home made system which with limited testing (as only me) I am not sure what other things can possibly go wrong.
    So I must reiterate again that you MUST consider the risks involved and mindful of on depending on such systems as a reliable defense mechanism.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  13. The Following User Says Thank You to MyGU8 For This Useful Post:
  14. #30
    84 Post(s)
    I also had a look at setting up something similar. Good idea to use Mineral Insulated Metal Sheathed (MIMS) conductors and gal piping above ground if you wish to keep your fire suppression system operating. It would only benefit you if you had your own power source too as power is usually cut in the event of a fire. You could use the controller to isolate your system from your mains power and start and connect your own power source.
  15. The Following User Says Thank You to mudnut For This Useful Post:
