Results 1 to 3 of 3
Thread: Problem starting gu patrol zd30
    Mar 2015
    I have my 2003 gu patrol running the 3litre zd30. I have owned the car for about a year now occasionally about once a week the engine light and glow plug light flicker on my dash and don't allow me to start the car. It's like the battery cable is loose or something however there is still power from the battery as the starter motor still works and turns the car over it just won't start like an immobileser is on or something any ideas of what it could be ? It can some times take 10 minutes of this light flickering before the car will start
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Possible a faulty ECU relay or the main ECU earths on RHS of the engine are loose or corroded.
  3. The Following 3 Users Say Thank You to Yendor For This Useful Post:
    BigRAWesty (6th January 2016), markstevo (17th January 2016), threedogs (27th January 2016)
    Mar 2015
    I pulled off all earth straps at the motor and battery and gave them a good clean back to fresh metal and let system reset it self by leaving it off for a while then put back on and haven't had an issue thanks for reply Yendor
  5. The Following User Says Thank You to markstevo For This Useful Post:
