Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Dual 12v compressor and air tank upgrade
  1. #51
    Jan 2014
    Hi SD. Did you made provision for airflow? My compressor gets quite hot.
  2. #52
    Expert Skitzyrex's Avatar
    Jul 2013
    Quote Originally Posted by sil3nt_dr3ams View Post
    These compressors have a different thread than normal nitto fittings, so out with the tap and die sets.
    Hey Silent,
    Can I ask what fitting you started with to put into the end of the compressor? I'm guessing 1/4 bsp? Then what did you cut it to, to get it to fit?
    I'm trying to do something similar and put a pressure valve off a tee piece and couldn't find anything to fit. Grr
    Thank you
    Mick
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  3. #53
    @ Srex idealy you want a non return valve and may be an air manifold to fit the pressure valve to
  4. #54
    Jul 2013
    Cheers mate, I have seen the manifolds but only in npt. I need to be able to get out of the compressor first, either npt or bsp to be able to attach one. I've already been to a couple of fitting shops including Enzed and it's not a common thread which is annoying.
  5. #55
    Which compressor did you buy ??
    and where are you??
    http://www.ebay.com.au/itm/12V-TRUCK...-/272056931559
    I have this one for air horn,,, front diff lock.
    Plus another for tyres , but too big for under bonnet installation
  6. #56
    @ strex I think looking at the compressor they have used a bolt thread from the head through the handle to
    the nitto fitting,,,,, either 10mm x 1.25 or 8mm x 1.25,,,,,,,,, Sounds right to me.
    Are you mounting it as well ,if so Id remove the handle, but thats just me.lol
    https://www.valvesonline.com.au/references/threads/
  7. #57
    Jul 2013
    @ strex I recond looking at the compressor they have used a bolt thread from the head through the handle to
    I did originally have the handle off 3dogs but that was a different thread again. So on that one handle there were 3 different threads. Talk about making it confusing. Haha
