Page 35 of 51 FirstFirst ... 3334353637 ... LastLast
Results 341 to 350 of 503
Thread: Fuel consumption / economy report
  1. #341
    Same as Kallen ,,,,, I heard vehicle manfacturers were allowed 10% error in speedo readings.
    Get a speeding ticket they only give you 3% error funny eh
    ADR's were changed a while ago now and the current formula is a tad hard to type out but is essentially...
    The speedo cannot underread at all at any speed (IE you can't be going faster than indicated)
    The speedo must overread by between 0 KPH + 4 KPH + up to 10% of the actual speed
    EG at 80KPH actual the speedo must read between 80 and 92 KPH (80 + 4 + 10% of 80 which is another 8)
    It is because of the 'new' ADR saying that it cannot overread that the Feds can get away with zero tolerance on speeding if they so choose
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    Sprock (3rd January 2016)
  3. #342
    We got 15.54l/100 on the highway from Melbourn in our 98 2.8L GU. Is there any way of improving that?.
  4. #343
    Anyone know how many litres in the main tank would be used when the light comes on?
    I decided to see what fuel eco i get but i wasnt anywhere near a servo to record the litres for a fill up.
    BigRAWesty (15th January 2016)
  6. #344
    Dunno mate. They usually allow 50k so maybe 10L
    Another question to all running sub tanks..
    Do yas fill up both tanks and work from both..
    As we know the sub transfers a bit each start up so the added extra could be giving false outcomes if just working from main tank use..
    There is about 20 ltrs left when the light comes on with mine anyway ,hope that helps
  8. The Following User Says Thank You to threedogs For This Useful Post:
    mudski (15th January 2016)
  9. #346
    Quote Originally Posted by Marc Allen View Post
    run 40psi for hwy driving and stick to 100kph as best you can
  10. #347
    I'll put $20 in the sub when I fill up if not going away, and transfer when the need arises.
    Going away I'll fill both obviously. $1.16 a ltr ATM here
  11. #348
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    I always try and have at least 1/2 tank full in the sub around town.
    I don't think the sub tank draws much on start up, maybe only couple 100mls
  12. #349
    Id always have some fuel in the sub, even if just to keep things lubed
  13. #350
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    I fill both tanks at the same time... once the main runs out i fill it with half of the sub tank.. once that runs out use the rest of the sub tank.. helps keep a bit of lube in the tanks at all times.
    Since changing from a Dawes to Tillix i have got a lot better economy.. not sure how as i have the needle/spool rate set about the same... I used to struggle to get 700km out of both... today my fuel light come on, on the main and it just clicked over 700km... So pretty much my whole subtank is bonus economy now...
    700km out of a main tank is about normal for a DI?
    And bonus was i got a whole tank worth of driving without having to replace my pistons
    2003 GU SIII Auto Grenade. All the goodies.
  14. The Following User Says Thank You to Softy For This Useful Post:
