Results 31 to 34 of 34
Thread: 5th gear low range manual, what speed should I get at 3000rpm? ?
  1. #31
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    48.64km/h.
    wouldn't the 24% be higher than the stock 50% reduction gear? Cause the gearbox output shaft speed is reduced by a lower factor (24% as opposed to 50%).
    1992 Nissan Safari Granroad LWB TD42 after market turbo RE4R03A (for now) 3" straight pipe
  2. #32
    Quote Originally Posted by tuckertrucker View Post
    No. I belive they are quoted as a % of what the stock gearing is. So if stock is 50% then the 24% would equate to a 74% reduction
  3. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (13th January 2016), MudRunnerTD (13th January 2016), tuckertrucker (14th January 2016)
  4. #33
    22 Post(s)
    Thats it, 85% of 2.02 =1.72 so, being that it is further reduced it is 2.02+1.72= 3.74:1.
    3.3:1 for 63's
    2.99:1 for 43's
    2.5:1for 24's
    96 GQ coil/Cab
    08 G6eT
  5. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    growler2058 (13th January 2016), MudRunnerTD (13th January 2016), tuckertrucker (14th January 2016)
  6. #34
    Aug 2015
    right that makes sence now, didnt realise the reduction was on the stock gear.
    Cheers guys.
  7. The Following User Says Thank You to tuckertrucker For This Useful Post:
    BigRAWesty (14th January 2016)
