Results 11 to 20 of 22
Thread: NATS Key .....
    Jan 2014
    Shepparton VIC
    I am trying to understand the above conversation....
    You got only two minutes to wind the window.....?
  2. #12
    Expert bsteveo's Avatar
    Jun 2015
    Melbourne, VIC
    Quote Originally Posted by escix View Post
    You're only joking right ?
    Yeah my commodore works from across the state but this thing you have to be nearly nose to nose with it , another thing that pisses me off is as soon as the keys off the electric windows don't work - the Commodore you can take out the key and close the door, walk & away come back a couple minutes later & just flick the window button and the windows go up - the bloody patrol as soon as you turn the key off windows are dead I know it's only a small thing but it is annoying
    2002 GU wagon 3.0lt , auto , piranha dual batteries , 3" lift , chip , needle & Dawes valves - just gettin started
    Sent from my HTC_0PKV1 using Tapatalk
  3. #13
    Dec 2015
    WA
    5 Post(s)
    The battery in the remote for my 2001 GU2 lasted around 10 years.
  4. #14
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Hmm Duno what's going on with it ....
  5. #15
    Common issue Adam. Mine did the exact same as yours. From a quick google search on the issue, chances were a new fob or battery for i wasnt going to be a permanent fix.
    So i went down to JB Hifi and bought a Warlock kit for $90 and spent a whole 20 minutes or so installing it and i havent looked back since.
    BigRAWesty (10th January 2016)
  7. #16
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Shit hot mate thanks 🏼
  8. #17
    I'm surprised all you guys have to be so close..
    My 08 works from behind the house..
    Roughly 30m and a stone home.. very happy with mine
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Sprock (10th January 2016)
  10. #18
    I have that kit in the gq.. is a great bit of kit.
    Legendary happygu's Avatar
    The new ones with the remote integrated into the key work much better .... I can be on the other side of a football field and check to see if the car is locked.
    The earlier ones were designed such that you had to approach the car at the right angle, or be virtually on top of the windscreen for it to work .. they were terrible, but it meant that you couldn't accidently unlock the car with your keys in your pocket from 40 metres away - not knowing and not watching .... the earlier ones made no sounds and had a really crappy indicator flash system, which meant that you had to watch like a hawk to make sure that it was doing what you wanted it to do.
  12. The Following 2 Users Say Thank You to happygu For This Useful Post:
    BigRAWesty (10th January 2016), Sprock (10th January 2016)
  13. #20
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Maybe they finally listened to all the complaints
    John
  14. The Following User Says Thank You to jff45 For This Useful Post:
