Results 1 to 10 of 14
Thread: urgent help
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    urgent help
    Hi had a major issue computer crashed with all my photos of the donor car being stripped, so now im stuck remembering where the bundy tubing from the filter exactly runs across the firewall and the positioning of the black cannister and bracket plate is located. If anyone has pics of their td42 with the engine out and some good pics of the engine bay it would be greatly appreciated.
  2. The Following User Says Thank You to Pezzer For This Useful Post:
    BigRAWesty (7th January 2016)
    Ok mime ain't stock but it's pretty close..
    The bracket sits on the shock bulge and the canister in front of the fuel filter..
    But.
    I've relocated my canister to under the fuel filter to allow a bit more room behind the battery.
    All done with stock hose bits
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Pezzer (7th January 2016)
    I have removed that entire manifold. Just ridiculous. So much extra plumbing, it all goes over to the drivers side mate. I have relocated my vac canisters to the drivers side also to make way for a large air box. Check out the last couple of pages of my build thread. I will jump on tappa and post some pics to if you like.
  6. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (7th January 2016), LaughingBeagles (8th January 2016)
  7. #4
    urgent help
  8. #5
    Note that your fuel lines cross over from the drivers side to your primer filter then straight back over again. Dumb design. I have also mounted that on the drivers side and removed the excess fuel lines off the fire wall.
    It's now mounted off the battery tray using the factory mount modified.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #6
    Jun 2013
    Gold Coast
    I like the cannister under the filtre looks neta...
  11. #7
    urgent help
    Quote Originally Posted by Pezzer View Post
    Sure. There is just sooo much plumbing running across the fire wall which is doubled up and not required.
    Note also it was in my way as this is the airbox going in...
  12. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (8th January 2016), Pezzer (8th January 2016)
  13. #8
    Jun 2013
    Gold Coast
    Westy would you have a pick of the other side as I cannot workout where the original return line is run this pipe seems to hit everything....IMG_1903.JPG
  14. #9
    Gimmi an hour mate I'll take one for ya
    Do these show you. You can just make out where they clip to the left of the air con penetration
  16. The Following User Says Thank You to MudRunnerTD For This Useful Post:
