Results 1 to 8 of 8
Thread: fuel lines swap or not TB42E TO TD42T
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Hi do I need to remove all the diesel lines from the donor car which is a long wheelbase, or can i utilize the existing fuel lines in my Shorty to supply diesel to the motor. I already have the diesel tank and filler fitted, although as the car used to be Lpg also hence a long range petrol tank was fitted.So to re run lines will be a real pain, I still want to utilize this tank also for diesel.....thanks for any help...
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    You can use the TB lines
    '96 GQ TD42t
  3. The Following 2 Users Say Thank You to Chappy For This Useful Post:
    BigRAWesty (6th January 2016), Pezzer (7th January 2016)
    Yea leave fuel lines.. some people leave the tanks to..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Leave the lines and tanks.
    Is there an EFI fuel filter in the chassis like the TB45? If so, remove it.
    I also had to remove the unleaded fuel restrictors in the fuel tank filler necks.
    Do you have an in-tank fuel pump? If so, remove it also and replace with a length of fuel hose.
    Sorry, just saw you fitted diesel tank..
    John
  7. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    BigRAWesty (7th January 2016), Pezzer (7th January 2016)
  8. #5
    Jun 2013
    Gold Coast
    Yes the long range tank has the efi pump, and the diesel tank is just that, I would like to hook up both tanks to fill together and empty through one. On the TD42t I have just the injector pump will I need a lift pum?
  9. #6
    Quote Originally Posted by Pezzer View Post
    Some people run lift pumps when running higher horsepower setups.
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
  11. #7
    Any turbo setup of any kind on a TD42 will have some benefit from using an electric fuel pump
  12. The Following User Says Thank You to Winnie For This Useful Post:
  13. #8
    Morayfield, QLD
    I fitted my lift pump where the EFI filter was. The metal lines had to be joined there anyway so it worked out well.
    FYI, I'm using my subtank as it was before with the electric pump transferring diesel now.
    John
