Page 590 of 1057 FirstFirst ... 588589590591592 ... LastLast
Results 5,891 to 5,900 of 10566
  1. #5891
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    What did you do to your Patrol today!
    Cheers guys. That's the loom I was looking at Roosim..
    But curious to know if it'll fit 08.. it should
    When I spoke to the audio guy at autobahn there are 2 looms available based on the age of he patrols - sometimes it's a bit hit and miss which one is required though - unfortunately I didn't take any photos of mine before I installed it though, otherwise I'd be able to tell you the exact one
  2. The Following User Says Thank You to Bacho86 For This Useful Post:
    BigRAWesty (4th January 2016)
  3. #5892
    Dec 2015
    Cudlee Creek SA
    Connector for 97-2009
  4. #5893
    Ran a power cable for rear power.
    Omg it's so easy when everything is clips lol..
    Did you run cable to the cut out in the cargo area ,,,,,or,,,,
    to the rear bumper. Dont forget to run a power outlet to the
    bullbar comes in handy for solar or camp lighting
  5. #5894
    84 Post(s)
    Took it to check the power gained after the headers fitted. 80.7 kw, up from 72 kw. Cheap mod and also better fuel economy.
  6. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    BigRAWesty (4th January 2016), Bloodyaussie (4th January 2016), threedogs (4th January 2016)
  7. #5895
    What did that set you back?
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Finally replaced one of the clips on the airbox today after it fell into the engine bay 10mths ago and vanished into that black hole that nuts and bolt go to.
    2003 GU SIII Auto Grenade. All the goodies.
  9. #5897
    84 Post(s)
    560 - 590 fitted. about 23000 ks of highway driving should see a cost recovery. It was done, because the manifold kept blowing gaskets at the engine pipe. It turned out to be a bent flange due to some dodgy welding at the factory. I am still waiting for the cash back for the engine pipe.
  10. #5898
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Dropped it off to get the head completely rebuilt. Not looking forward to the bill, but a necessary expense.
  11. The Following 2 Users Say Thank You to SiberianPatrol For This Useful Post:
    mudnut (4th January 2016), Stropp (4th January 2016)
  12. #5899
    Jan 2014
    Shepparton VIC
  13. The Following User Says Thank You to MyGU8 For This Useful Post:
  14. #5900
    How much for the dyno test lol??
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
