Page 586 of 1057 FirstFirst ... 584585586587588 ... LastLast
Results 5,851 to 5,860 of 10566
  1. #5851
    Haven't driven it since the day before Xmas, probably its longest rest.
    Pretty confident it will start first time.
    What I did do was vacuum the inside, had a heap of plastic bits from installing
    the carling switch mounting blocks
  2. #5852
    Feb 2011
    Shed
    45 Post(s)
    Gimme maf a clean.
  3. The Following User Says Thank You to growler2058 For This Useful Post:
    rusty_nail (29th December 2015)
  4. #5853
    Gimme maf a clean.
    You need a catch can ASAP your inlet hose to the turbo has been very oily at some stage
  5. #5854
    Patrol Freak gaddy's Avatar
    redlands
    Took it out for a spin , keyman , pebbly beach , wooli , via the dirt
  6. The Following 4 Users Say Thank You to gaddy For This Useful Post:
    mudnut (31st December 2015), Stropp (29th December 2015), threedogs (29th December 2015), TPC (29th December 2015)
  7. #5855
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    pulled apart a swivel hub... one bearing fell apart now just change a couple more things the back together, then the other side....
  8. #5856
    Unafordable
    4 Post(s)
    Finally fitted the fuel cooler.....
    Thanks to Kenco Racing QLD, Mr Nissan providing some spare mounting holes and Volvo Trucks Corporation Volvo FH cab engine air intake piping rubber spacer it was a breeze to install. I can see fuel temperatures actually going down when engine load is off instead of just climbing up and up....
    Should've done it long time ago!
    B/R
  9. The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
    LaughingBeagles (29th December 2015), threedogs (29th December 2015)
  10. #5857
    Oct 2015
    Aldinga Beach SA
    Trapped in Westfield 'shopping' with swmbo , got talking to a Mr Minit guy and ended up with a new spare key for the GU. $130 cheaper than the dealer...
  11. #5858
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by Roosim View Post
    What year Patrol do you have?
  12. #5859
    OHHhhhhh Keyman as is a man covered in Keys Doh, lol
  13. #5860
    Quote Originally Posted by Rumcajs View Post
    B/R
    Looks like a very affordable mod, does it allow the fuel to be delivered more efficiently
    A better burn rate?? , I can see how the fuel would be denser,being cooler
