Results 1 to 10 of 456
Thread: Rockets Wagon
Threaded View
    177 Post(s)
    Very nice Rod.
    I've found all NPT fittings I used were very tight, but still had more go on them. Not sure if this is normal or not as they are compression fitting so maybe they are designed to be that way ? Heck I even had a breaker bar to put one on the other day.
    I am very keen to see the results of this. Are you going to replace the thermostat as well ? Also did you have much trouble getting to the drain plug on the block close to the turbo ? Looks like a bitch to get to.
