Results 1 to 5 of 5
Thread: Front A/C pipe to rear A/C unit, how to remove them?
    Dec 2015
    The front A/C pipe where they are welded together have a hole in them, have disconnect them. Now finding it hard to remove them from between chassis rail and out through the engine bay. If someone could give a hint on how this done, would be nice. Looks like I may have to jack engine up a bit as its a tight squeeze? Cheers
    By the way how do you find this message after you have posted it? As you can see I new to this forum stuff. Cheers
    Does the system still have gas in it ,if so that will need to be evacuated first.??
    Also what year ,model do you have it might help with an answer
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Nissan07 (11th December 2015)
    Dec 2015
    No gas in system. Patrol 2007 GU ZD30 DDTI Engine.
    I dont think many people, if any really, would have done what you need to do... So you may be the guinee pig for this one...
    Advanced Potsy's Avatar
    Jan 2015
    Adelaide SA
    Hey mate, not sure if the system on your bus is different to mine (2000 patrol) but if they got in there they have to come out somehow and jacking the engine up sounds like a lot of work to do some thing like that.
    Easy for me to say without seeing it I'm sure!
    If it's the suction line (larger pipe) and is insulated by pulling the insulation off you may get a bit more room.
    If it's damaged and going to be replaced then it's easy to get out with the help of some tube cutters but the new one needs to go in and if it can't go through the existing spot you may need a different or custom piece.
    Can you put any photos up for us to have a look at? I hate being beaten by air conditioners!
    2000 GU, TD42T, bullbar and roof racks, 2inch lift, winch, front and rear air lockers, 3inch Scotts rods dump and exhaust kit.....more to come!
  7. The Following User Says Thank You to Potsy For This Useful Post:
    Nissan07 (20th December 2015)
