Before you go any further $ wise get a decent mechanic to do a compression check.
You have to rule out any underlying engine issues if you are doing a lap.
Next, does it overheat on LPG or Petty or both?
They run hotter on LPG anyway.
Is it using any coolant?
You may only need a decent LPG tune or it could be something much more problematic.
Your Thermo should be wide open at 97 not just opening.
Massive Spots on the roof or on top of the bar will be cop bait in W.A. (they are illegal in all states but some police are more rabid than others).
There are any amount of vehicles running around with big Light Force with no probs so you are treating a symptom not making a cure
