Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 146
Thread: Soft Shackles Group buy. Expressions of interest
  1. #101
    Yeah but they are 10mm. I am keen on some 12mm. If I have to I will make myself a couple.
    BigRAWesty (16th December 2015)
  3. #102
    12mm !!! ...
    Holy Cow dude, you planning on snatching Unimogs?
    That will be around a 20 tonner.
    I think you will be amazed how big a 12mm shackle will turn out to be when you make it.
    I have a couple of 6mm, a couple of 8mm and one 10mm.
  4. #103
    More from the same shop,
    Some one should do a U tube video on how to use these properly,
    and where they can be used, just saying LOL
    http://www.ebay.com.au/itm/Soft-Shac...item1a08048739
  5. #104
    Well if you guys want 12mm and ain't fussed about testing then I'll do it as I can do much cheaper for ya
  6. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    MudRunnerTD (16th December 2015), threedogs (16th December 2015), TPC (13th January 2016)
  7. #105
    Ok. So let's do this. Chrissy rush is over..
    Getting a price again but it should be close to the $21 plus postage..
    That's for the 12mm rope shackle..
    If your keen I'll need a 50% deposit before I order..
    copy and paste your name to the list.. need the 50 as per before for it to happen. .
    BigGQWesty x 2
    .......... TPC's Avatar
    63 Post(s)
    BigGQWesty x 2
    BigGQWesty x 2
    TPC x 2
  9. The Following User Says Thank You to TPC For This Useful Post:
    BigRAWesty (13th January 2016)
  10. #107
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    BigGQWesty x 2
    TPC x 2
    Chubba x 2
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  11. The Following User Says Thank You to Chubba For This Useful Post:
  12. #108
    Ok guys.
    For the 12mm shackles in a 60mm diameter they'll be $24 plus postage.
    10mm x 60mm shackles are $21..
    Available colours are
    Grey blue red and yellow..
    I'm thinking we go Red..
    But seeing g if we can mix and match
    So.
    Any of you previous blokes still keen??
    Bump bump. Anyone else
    Put me down for 2 red thanks Kallen.
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (17th January 2016)
