Page 574 of 1057 FirstFirst ... 572573574575576 ... LastLast
Results 5,731 to 5,740 of 10566
  1. #5731
    Expert King_ady1's Avatar
    Beveridge, Victoria
    This is crazy man. I wish I were there too. It would be a great experience. Just don't freeze to death on us!! We want to hear all about the trip!!
  2. #5732
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    I'll be gone for about 2 weeks so I'll be offline until just before Christmas. Plan to do a full write up when I get back
  3. The Following 4 Users Say Thank You to SiberianPatrol For This Useful Post:
    BigRAWesty (6th December 2015), jack (6th December 2015), taslucas (10th December 2015), threedogs (7th December 2015)
  4. #5733
    Beveridge, Victoria
    Awesome. Can't wait!! Lots of pics
  5. The Following User Says Thank You to King_ady1 For This Useful Post:
  6. #5734
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Out with the old....
    In with the new....
  7. The Following 3 Users Say Thank You to Bacho86 For This Useful Post:
    BigRAWesty (6th December 2015), threedogs (7th December 2015), Winnie (6th December 2015)
  8. #5735
    Quote Originally Posted by King_ady1 View Post
    It would be like staring at a piece of white A4 paper wouldn't it lol
  9. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (7th December 2015), growler2058 (29th December 2015), King_ady1 (7th December 2015)
  10. #5736
    Beveridge, Victoria
    Ye but there will be a line lol
  11. The Following User Says Thank You to King_ady1 For This Useful Post:
  12. #5737
    Advanced modustollens's Avatar
    At those temps, the air is usually very dry with little humidity left to precipitate. The air is very dense and thick and the stars at night are sharp - I can see so much better in the cold - maybe less refraction in the cold that is void of any moisture. High wind can blow stuff around already on the ground though.
    Here in Kazakhstan the temps are below -40 always for many weeks; it never hit -50 yet for me here, but -48 arrived once; but it is really too cold for snow when it is like that.
    Back in Canada where I am from the temps can get below -30, but not often; -5 to -15 is pretty common and it is here where there is a tonne of moisture in the air from the lake; when the air moves up and inland then it will dump like mad. Last year it looked like this:http://www.huffingtonpost.ca/2014/02...n_4732139.html
    If below -22/-25 it will usually be clear sky, with no clouds and no snow. In fact, when camping out in the winter, we head out of the bush to the field and look up at the sky - if we see the clouds clearing then we chop more firewood - the temperature always falls when the clouds clear!
    In Canada, where I am from, we will get more snow in one day than the Kazakh town where I am living now will get all winter (big picture for your viewing pleasure):
    http://modustollens.org/photos/galle...2009-rough.jpg
    I put a new power steering belt on my machine; no one had size 775; I tried a 800: too big; I tried a 750, too small. I spent hours and hours going all over the town and one guy had one 775 in the bottom of a box in the back room. But only one.
    So, I had to install and remove belts too many times. It is a PITA to replace given that, depending on the thickness of the belt, it is very hard to get it to squeeze under the belt mounts for the alternator. The 775 was too thick to be squeezed under so I had to loosen the bolts holding the fan clutch on to free up the belt wheels enough to 'convince' the belt to pass through.
    MT
  13. The Following 10 Users Say Thank You to modustollens For This Useful Post:
    Clunk (10th December 2015), growler2058 (29th December 2015), jack (7th December 2015), mudski (8th December 2015), Rossco (7th December 2015), SiberianPatrol (8th December 2015), Stropp (8th December 2015), taslucas (10th December 2015), TPC (7th December 2015), Winnie (7th December 2015)
  14. #5738
    Fitted in the relay plugs into the OEM Relay box next to the main battery. To use the five empty spaces that were in there, rather than having them in a separate relay box....Now to just wire them in after I find a decent battery terminal....
  15. The Following 2 Users Say Thank You to mudski For This Useful Post:
    foggs (8th December 2015), gubigfish (8th December 2015)
  16. #5739
    177 Post(s)
    Fitted up the rear work / flood / reverse light from LED Light Co.
  17. The Following User Says Thank You to Hodge For This Useful Post:
  18. #5740
    Mar 2011
    14 Post(s)
    Nice work hodge - did you connect that up to a 3 way switch by any chance? I tried doing mine on the weekend, but couldn't find a good spot to hook up the reverse activation in the front without cutting up the loom ... Best advice I could find was the "yellow wire" but there were lots to choose from! Cheers
  19. The Following User Says Thank You to Bacho86 For This Useful Post:
    Hodge (8th December 2015)
