Results 1 to 10 of 15
Thread: Covering the intercooler with a blanket
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Yes, you read the title correctly. Here in Siberia, we are heading into our cold months of -30C or lower temps and one of the common practices to help protect the engines in this weather is to put a fiberglass-type blanket under the hood, over the engine. The problem is, none of them have a cutout for the Patrol intercooler (off-center). These blankets are densely woven but thin enough to fit completely over the intercooler with the hood closed without any interference.
    My question is this - will the intercooler being covered like that do any kind of damage to the engine? I know the intercooler is there to cool the intake air for more efficient fuel burn, but the air is already super-cooled from the frigid temps, and keeping the engine warm is the most important factor in these conditions.
    Any thoughts or suggestions? I guess I could always cut my own hole, but these things are super dense, heavy and wouldn't be easy to cut.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I would guess it should be ok
    it will make it a lot warmer than usual - maybe Northern Territory type warm
    but your right, the intercooler is designed to have the air flow through it to cool down the air flowing through it
    even if the outside ambient temp is -30C the air from the turbo will still be at about 350-500C
    so it would be the same as NOT having the intercooler on
  3. The Following User Says Thank You to Bigcol For This Useful Post:
    SiberianPatrol (29th November 2015)
    Jul 2015
    Siberia
    Thanks, Bigcol. I will run it for a while and keep an eye on my EGT gauge. If things get too hot, I'll rework it to get it uncovered. A lot of guys cover their front grill as well but I haven't done that yet. We have a warm spell now - only -5C now, so I'll wait to see if it's needed.
    In the temps you are talking. I don't see a problem.
    Jul 2015
    Siberia
    I'll have to keep an eye on it when it warms up close to 0C, but colder it will be a definite help
    1999 GU RD28Ti; mechanical injector pump, 5kBt Webasto circulation heater, 33" Yokohama Geolander I/T, SaaS boost & EGT gauges, 2" Ironman suspension...more to come
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    5kBt Webasto circulation heater is that from a truck ?
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Jul 2015
    Siberia
    Quote Originally Posted by altech View Post
    This is the unit. It gets installed under the hood and ties in with your cooling system and is powered by diesel from your tank. It heat and circulates the antifreeze so that you don't have cold starts in the winter. It's a pretty common install over here for both diesels and petrol vehicles. Helps make sure the engine doesn't freeze in extreme temps. So far at -25C it works great. It heats the engine up to around 30C before starting.
  10. The Following 2 Users Say Thank You to SiberianPatrol For This Useful Post:
    Bigcol (29th November 2015), MudRunnerTD (30th November 2015)
  11. #8
    Quote Originally Posted by Bigcol View Post
    snip...
    Strewth Col, I hope that 350 to 500 deg C figure is a typo.
    Anything more than approx 150 degrees (on a 20 to 25 degree day) charge air temp would be a major concern
    On a -30 day the charge air pre intercooler maybe would hit 50 ish and would be flat out cracking double figures post cooler
  12. The Following User Says Thank You to the evil twin For This Useful Post:
  13. #9
    I think he means post-combustion. I.e. Exhaust gas temp
  14. #10
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    too much wine while sitting in the sun...............
    yes ET, wrong figures, as Winnie said - that would be the EGT's, and I got them confuddled with the air into the intercooler.......
    shouldnt mow the lawns, drink red wine while still in the sun, and then go onto forums............ had a nice nap though.........
