Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Child restraint anchor points
    Pretty sure the gu patrols have 3 or 4 points..
    2 on the middle row and either 1 or 2 in the rear..
    As Mr said the problem is the 50/50 split seats for the 3rd in the middle.
    I did talk to an engineer in Adelaide and he said he's happy to approve with a nut welded to a peice of 2mm sheet about 150mm square stitched to the underside of the floor..
    And have a bit of steel folded up to cover the split.
    A few hundred bucks and was good to go..
    Have since lost his number but if you jump on your state government website you should be able to track down a local engineer.
    Feb 2015
    If you get one attached to the roof you don't need to worry about he 50/50 split. I got mine installed by a mobile anchor point fitter.
  3. The Following User Says Thank You to Rossko07 For This Useful Post:
    BigRAWesty (24th November 2015)
  4. #13
    Quote Originally Posted by Rossko07 View Post
    Can you post a pic of your setup please. Keen to see how it looks.
  5. #14
    Feb 2015
    Got one for you.
    This was my only option for second row middle seat as I have rear ac in my gu.
  6. The Following 2 Users Say Thank You to Rossko07 For This Useful Post:
    MudRunnerTD (24th November 2015), P4trol (17th February 2017)
