Page 27 of 28 FirstFirst ... 25262728 LastLast
Results 261 to 270 of 280
Thread: Winnie's Warn hi mount rebuild
  1. #261
    I noticed mine did that a while back and I had to jiggle the release handle a bit and it popped out another mm or two which released it fully.
    Had me stumped as well.
    Ie; pull handle out and wiggle left and right whilst pulling.
    Hopefully mr winch man can shed more light mate.
  2. #262
    I hope it's as easy as that, I'd really rather not have to pull it out of the bar again... lol
  3. #263
    They are a bugger of a thing. You will find that it is likely the brake shaft cam lock has stayed slightly compressed meaning it is engaged. Even after a full rebuild I have had this problem quickly.
    So the easy fix is NEVER Use the free spool...... Winch out will winch out nearly as fast as you need the line.
  4. #264
    One of the reasons an air freespool is a winner too. Also when running 24v through a 12v motor they don't like reverse so the air freespool with 24v is perfect as winch out sux.
  5. #265
    Obviously I would rather have the free spool though... hmm what a bugger.
  6. #266
    Yeah you'd think for sure. Truth is though mate when your using the winch in anger the navi would use the free spool to pull the rope out and hook it up then would have to run back and engage the free spool again. Reality is you will winch out every time, they hook you up, winch on and out you go.
    Because there is no heat build up its really not an issue.
  7. #267
    Pin it and forget it. The navi controls at the headlight help with this too.
    Winnie (5th January 2016)
  9. #268
    So I finally got to put the winch to the test! Farrrrk these things are awesome!!
    Yes, that is two 80 series =]
  10. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    AB (15th November 2015), Maxhead (15th November 2015), Stropp (15th November 2015)
  11. #269
    Sweet, is that down near the coast somewhere? Looks like fun. Yeah they're a good winch☺☺
  12. #270
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Well done mate but cant you leave the tojo,s alone
