Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 72
Thread: leaking big time
  1. #31
    Think I had a bit of a win, that corroded pipe broke so I could just fit a new longer piece of hose.
    went around the block a few times and temps were good. Before I would have lost coolant and
    over heated , just need to keep and eye on it, a couple of drips when I got back
    but Ill put that down to expansion
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Bob (14th November 2015), Stropp (14th November 2015)
  3. #32
    Hopefully there are a few dead ZD30's at the local 4x4 shop I can snaffle that pipe off
    and replace mine.
    Found some 5/16 copper pipe on Ebay that will probably last longer.
    I have a pipe bender as well .
    @ Roofy yes it goes to the EGR, thanks
    Sir Roofy (14th November 2015)
  5. #33
    and replace mine.
    I'm sure there will be plenty.
  6. #34
    Just took it for a decent spin giving it a bit and couldn't get the temp to go past 85 c
    So I think I can safely say its OK now,
    I'll still replace the oe pipe with some 8mm copper,
    combined with the new overflow tank my cooling system is re-co'ed
  7. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Bob (14th November 2015), jay see (14th November 2015)
  8. #35
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Great News John
  9. #36
    Quote Originally Posted by Bob View Post
    Great News John
    Would have been a different story if it was the head,,
    very relieved thats for sure $3k just for the head and motor has to come out
  10. #37
    Nov 2013
    Gold Coast
    My expansion tank was replaced as it was deemed to be brittle etc when my radiator had a working bee on it after I found a few drops of coolant under it on the concrete floor in the garage.
    Stuff just does not last; it was an Aug 1989 build and it only lasted until mid 2015. Suppose the brakes will need to be looked at some time too!
  11. The Following User Says Thank You to Chimo For This Useful Post:
    threedogs (14th November 2015)
  12. #38
    Im still losing water but not over heating ,
    looking from underneath I think my water pump is leaking.
    Need this sorted asap besides being a daily ,Cod opening is very soon lol
  13. #39
    177 Post(s)
    You're probably sick of me mentioning this but I suggest you take the Patrol somewhere where they see zd30s daily like 4x4 obsession in Melton and make sure your timing over isn't leaking.
    I was in the same mind set as you, thinking it was this and that, water pump, coolant tank... Hoping it wasn't the timing cover but in the end it was. At least that way you'll stop second guessing everything.
    Tapatalked from S6
    177 Post(s)
    When I spoke to Brett as 4 x4 obsession he said they do 3-4 a week .... They will know the moment they see it if it is the cover or not.
    Tapatalked from S6
