Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 104
Thread: My ls conversion...
  1. #81
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Shes pretty much finished... just need to make up 4 inch intake frm throttlebody back to the airbox... then its off to get exhaust and engineering done hopefully end of the week...
    Sent from my SM-N915G using Tapatalk
  2. The Following User Says Thank You to mullet_hunter For This Useful Post:
    BigRAWesty (10th November 2015)
  3. #82
    Shit yea. What a build..
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    mullet_hunter (10th November 2015)
  5. #83
    Feb 2015
    Will post up a vid soon..
  6. #84
    Advanced Finezy's Avatar
    Geelong - VIC
    wow... read this whole thread, as i was reading it became suspenseful and all i wanted was a vid of it in action and then i arrive here lol.
    what a bummer... ah well... subscribed! :P
    2001 GU II ST, 3.0di, Auto, All NADS done, Nissan Snorkel, 50mm Lift, 35's....
  7. The Following User Says Thank You to Finezy For This Useful Post:
  8. #85
    Feb 2015
    Haha il upload a vid soon.. hopefully can get my zaust done tomorow.. then i can finally drive it.. im pretty tempted to have a blast arnd the block but im still only running just open headers.. so shes loud as...
  9. #86
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by mullet_hunter View Post
    Yea man hold back - be a shame to get a canary without having any road time.
  10. #87
    Feb 2015
    Did a bit this arvo.. Mockd up my air intake.. finally got all my electrics sorted.. had a problem with my fuel pump blowing fuses but thats all sorted nw.. was basically earthing out my bulkhead fitting frm the pump.. ie it was making contact with the body when i bolted the tank back up in place.. causing it to arc out.. so i fliped the bulkhead fitting.. had the excess thread going into the tank and the head of the bolt on the top side of the tank... there were like 3 or 4 wires i had to tap into to get everything working mickey mouse.. tacho for dash.. power to ecu and a switch and light setup to manually overide ecu to turn thermo fans on and off for river crossings etc.. was a bit tricky as ecu controls when thermos come on and off... anyways everythings working as per normal on the dash which im pretty happy with.. temp.. oil.. speedo.. tach etc..
    Did a final solder of wires and taped up loom... bolted up ecu and fly by wire module up under dash.. happy days..
  11. #88
    Feb 2015
  12. #89
    Feb 2015
    Ok for some reason it wont let me post or upload a vid.. anyone nw hw?
  13. #90
    Simplest way is to up load to photo bucket or whoever and then link it in
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    mullet_hunter (11th November 2015)
