Results 1 to 10 of 53
Thread: Truck lift - Your opinion is wanted!
Threaded View
  1. #10
    Expert GUte's Avatar
    Perth
    I wouldnt bother with the body lift, unless running huge tyres (37+)
    I would recommend fitting drop boxes if going 4-5 inch lift, much cheaper than new radius arms and often give a better ride.
    For 4" you will need
    coils
    shocks
    castor correction (drop boxes or radius arms)
    panhards front and rear
    adjustable draglink (centres steering wheel)
    extended sway bar links (if you are running them, im only running rear)
    may as well get a new steering damper while you are doing it
    zordos do good kits http://www.zordos4wdsuspension.com.a...d=49&Itemid=53
  2. The Following 2 Users Say Thank You to GUte For This Useful Post:
    HippoNZ (11th April 2011), Robo (25th August 2012)
