Results 1 to 7 of 7
Thread: Winch rope question
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Winch rope question
    Is it best to wind your synthetic rope on all nice and square and tidy or to wind it on criss cross and random?????
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    Fisrt layer tight then random, well thats how I did mine
    Yeah, I do one neatly in a roll, then cross straight over twice, then neat... Etc
    Same here. Left to right in neat way. Only issue with this is if you use the winch and dont pull the entire length of rope out, when the rope is under stress it pulls through the rest of the coiled rope on the drum. If you get what i mean. If i had room i would criss cross it may be. Dunno....
  5. #5
    Oct 2013
    Adelaide
    5 Post(s)
    Yes I think that sounds good.
    Cheers fellas.
    "GO YOU CROWS"
  6. The Following User Says Thank You to Chubba For This Useful Post:
    threedogs (7th November 2015)
    Neat layer then full crisis cross a couple of times then neat layer then full criss cross a couple of times and so on. Using this technique will stop the rope being embedded into the spool layers.
    Winnie (7th November 2015)
    Yep this is the bloke I learned that from =)
  10. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MudRunnerTD (7th November 2015), Stropp (7th November 2015)
