Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Sliders and Aux Tanks
    Patrol Guru
    Jul 2014
    6 Post(s)
    As far as I was aware, GQ's only came out with the one tank from factory, around 85L (at the rear). This could be different for diese/ute variants. Certainly my GQ only had the one tank until I installed the aux tank.
    Yeah, my Aux tank is an LRA, so 68L is probably right, add in fuel in the line etc, and it probably feels like a bit more.
    For Gas, normally the rear tank is removed, and then they add an aux tank in the centre - depending on the gas mob these can be 30/40/50/70L units from what I've seen.
    As for converting to LPG, I do too many kms offroad in the high country, often switching between the tanks well before I get to a servo, so while it would save me money, I'd be losing a lot of my off road 'range'. Aside from which, too many servo's still don't have LPG. Would be nice for the local trips though.
  2. The Following User Says Thank You to Throbbinhood For This Useful Post:
    dom14 (30th October 2015)
  3. #12
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    GQ main tank is 95 lt.
    aux. tank is 73 lt
  4. The Following User Says Thank You to liftlid For This Useful Post:
  5. #13
    Legendary dom14's Avatar
    38 Post(s)
    Thanx guys. Yeah, it's kinda clear to me now. I obviously got the wrong info.
    LPG can work if you got three tanks. I got two atm and the third one going in soon(scuba tank).
    With all the three tanks in, around 230L total capacity, I wil effectively get 1000km+ of range full tank on LPG, and coupled with petrol tank and some jerry cans, I should be ok.
    Yeah, my idea is to fill all three LPG tanks at the last cheapest LPG station before I head deeper into the wilderness.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  6. #14
    Patrol Guru
    Apr 2011
    Melton
    To answer the original question.
    I have LPG and have had both sizes of sub-tanks (55 and 75 L) - (im currently looking for another sub tank - as I keep damaging them off road - next tank will have a bash guard)
    I made my sliders that clamp around the chassis in 2 places, and mounted at the front?
    There was enough room between the tank / chassis for the slider bracket.
    I had to bend the brake lines run alone the drivers chassis rail, away from the chassis to give room and ensur that the would not rub on the slider (onlt were the brackets were)
    Dom could you pls provide details as were your LPG tanks are mounted and size
