Results 1 to 7 of 7
Thread: Differental Thrust
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    Differental Thrust
    Hi guys, I've heard about some trucks with dual live axles, further more having a 60/40 split of torque between the two axles. Meaning one axle gets 60% of the engines torque, while the other axles recieves 40%. How does this work? How is this achieved?
    Cheers, Dylan.
    Very common these days in virtually any All Wheel Drive.
    Vehicle just requires a centre differential which in Off Road application will also have a locker
    Torque division from front to rear controlled by onboard 'poota and/or viscous coupling or variable clutching or mechanical torque splitting.
    There are almost as many methods as there are manufacturers
  3. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Chubba (28th October 2015), tuckertrucker (27th October 2015)
    Aug 2015
    Oh wow, I didn't realise its that easy to do.
    I wouldn't say easy.. just heaps of options lol..
    Imo if your looking at a 6x6 so both rears are driven at all times..
    Twin open diffs with lockers fitted..
    Be a lot easier.. but still a lot of work..
    Aug 2015
    Slightly off the original topic now, but can torsen diffs be fitted into patrols? Wouldn't they be ideal, as they lock as soon as a wheel breaks loose, and when on paved surfaces they allow differential action. No need for a diff locker or LSD.
    Quote Originally Posted by tuckertrucker View Post
    Anything can be done.. it's just how deep are your pockets and how nice is your engineer..
    Aug 2015
    yeah good point, theyre not cheap
  9. The Following User Says Thank You to tuckertrucker For This Useful Post:
    BigRAWesty (29th October 2015)
