Results 11 to 20 of 22
Thread: tyre inflators
    What you want to do whilst the tyre is inflating for a few minutes?
    My Aldi compressor, which is the same as those Mean Mother ones, just has the clip on chuck and it keeps pumping away until I look at the gauge. One could be made to fit inline from the chuck to the valve using a pressure relief valve so it just releases the air from the compressor but you'd need to put a one way valve in aswell so the air doesn't come back out once the pressure is reached. Could be made pretty easily. Is it worth your while though?
    Hmm, I think I have most of the parts here to make something. I might have to look into this now...
    Lol
    If you want to go "auto" for the vast majority of 12 volt jobbies then you will need an adjustable pressure regulator and switch.
    The reg will have to be adjustable so you can set what pressure to inflate the tyre.
    The switch will be to turn off the Compressor.
    If you don't have that the compressor will just run it's guts out while you are dicking around elsewhere and not needed and either overheat or exceed it's duty cycle.
    The reg is easy but the switch set up would be tricky
  2. #12
    Patrol Guru
    Jul 2014
    6 Post(s)
    How do you get around the 'having to turn it off to read the right pressure' aspect?
    As in, I've never had a gauge that was accurate when the compressor was still pumping, always have to turn it off first to be even close.
  3. #13
    Nov 2014
    Thanks Mudski,
    I also have an portable compressor and from what you wrote I found this,
    https://ditchingsuburbia.com/blog/on...r-installation
    similar to your idea. Is it worth it? Maybe not, but I love to tinker lol.
    If you do make one up show us some pics.
    1994 GQ 4.2L Y60 turbo Diesel Patrol ute (was a wagon), 4 inch lift, 2 inch body lift, 33 inch Maxxis Bighorn Tyres, endless air compressor, front and rear lockers, 25L water tank, endless hot water, winch, rock lights, reverse camera, dual battery.
  4. #14
    Nov 2014
    Quote Originally Posted by ova50 View Post
    Some tyre shops did have what was called a "Green ring valve stem".
    An Aussie invention, looked like a normal tubeless valve that was fitted to the rim the same as a regular tubeless valve.
    After inflating the tyre to the correct pressure you could turn the stem so the green ring could be seen.
    If the pressure dropped, the green ring could not be seen. The green ring would appear again when you inflated again.
    Not sure if they are still available.
    Best to ask a tyre shop
    You can get those one that replace the valve cap but chances are they would get knocked off.
    Looks like "Green ring valve stem" is to do with Nitrogen, that was just a quick glance.
  5. The Following User Says Thank You to Tigger77777 For This Useful Post:
    ova50 (26th October 2015)
  6. #15
    Nov 2014
    Quote Originally Posted by Throbbinhood View Post
    I do heaps in the time that my tyres are inflating.. Clean the lights/mirrors/windows, put the snatchy away if it's not dirty, wind in winch rope, put any rubbish or whatever in a bag, socialize with others, etc.
    Plus, means I'm not huddling over for a valve that's at the bottom leading to a sore back.
    Mine has a clip on chuck, and I've got a digital pressure gauge that I use and just clip em on off every now and then. I know roughly when I'm close to pressure.
    That said, would be great to be able to set 38psi and walk away, and when I hear the relief open up, time for the next wheel.
    That's the idea, more time for other things
  7. #16
    At OVA50 I have those TPMS its just a valve cap thats green
    at 38 psi and should turn red when my pressures drop.
    You can buy them for different pressures,
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #17
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    The Green Ring was invented by a Sth Aussie guy maybe around 1989 -1990. (I think his name was John Van Leeuwen)
    They were to replace the std valve, had nothing to do with nitrogen.
    I had some on a vehicle about 15-18 years back, but as mentioned, not sure if they are still available.
    Was a CRD
  10. The Following User Says Thank You to ova50 For This Useful Post:
    Tigger77777 (26th October 2015)
  11. #18
    Thats why you need a pressure reg.
    It will decouple the supply pressure (compressor) from the tyre pressure
  12. #19
    Any amount of gizmos out there...
    Here is a couple
    LED self adjusting http://www.ride-on.com/smartcap.html
    Red/Green plunger style http://www.redcatindustries.com/tyre...re-indicators/
  13. #20
    I have one of these ones,most of the time the tyres are all the same,gives me time to do other things as others have suggested
  14. The Following 5 Users Say Thank You to Avo For This Useful Post:
    BigRAWesty (26th October 2015), Clunk (26th October 2015), Winnie (26th October 2015), Wizard52 (22nd November 2015), Woof (26th October 2015)
