Page 22 of 46 FirstFirst ... 2021222324 ... LastLast
Results 211 to 220 of 456
Thread: Rockets Wagon
  1. #211
    Coming along very nicely mate! Well done
    Rocket55 (18th October 2015)
  3. #212
    476 Post(s)
    Looks awesome Rod.
  5. #213
    176 Post(s)
    Looks great Rod. Measure twice, cut once method for the bonnet ey...
    This thread is pretty much a "To do" and " How to do" for me, since our cars are identical. lol
  6. The Following User Says Thank You to Hodge For This Useful Post:
  7. #214
    Patrol Guru Rocket55's Avatar
    Sydney
    Haha I know what you mean, There's a couple of rigs on here and the other site that I get my inspiation and instructions from too, although mostly just search... Usually find what I'm after but generally also find about 3 other things that I should do as well.
    Cheers Rod
    My Build 2005 TD42TI
  8. #215
    Sydney
    Don't follow this install mate as I stuffed it up I should have cut a nice rectangular hole joining up the drill holes from the foam blocks on the cooler. Instead I used these as a reference to ensure the scoop was centred over the cooler (front to back) then traced out the inner lip of the cooler template and cut that as such the foam on the cooler now won't touch or seal on the bonnet... I'll have to look at some infill panels or find another bonnet at a wreckers...
    Are all the bonnets the same? If I just find a GU 4 onwards bonnet off anything I should be right, given that I will be cutting my own hole in it anyway. Any suggestions as to where I can find one?
    Cheers Rod
  9. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (19th October 2015)
  10. #216
    176 Post(s)
    Damn mate. That's no good. So, the way I understood it, you followed the paper template you had on top of the bonnet ???? But instead should have cut the inside-out where the foam stuck to the bonnet ?
    Edit: I reckon wreckers are you best bet mate.
  11. #217
    Sydney
    Yep, that's exactly right. I really don't know what was going through my head, not much obviously! I'm so pissed with myself it's not funny, it's seriously just a hassle I could do without at the moment.
    Could have been worse I guess, at least it's only a bonnet and relatively easily fixed, just a pain in the arse.
    I'll give a few wreckers a call today and see what the go is. Depending on the cost and what colour they have, if I have to get it painted anyway, I can buy new bonnets for just under $350 without searching to hard.
    Cheers Rod
  12. The Following User Says Thank You to Rocket55 For This Useful Post:
  13. #218
    Thomastown, Melbourne
    6 Post(s)
    I fitted one of these scoops last week and nearly started drilling when I thought I had it centered but something did not seem right so a checked about 8 times until I checked the lines of the template and realised that the drill holes were way off... Im glad I checked so many times as in the past I would be in more of a hurry to get it done and would have missed this.
    Bloody sucks mate big time and I do think they should be a little clearer in the instructions.
  14. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Rocket55 (19th October 2015)
  15. #219
    Sydney
    Yep, my mistake. Although if the instructions had a dotted rectangle in the middle of the template saying "your cut out should be in this approximate location, see instructions" then the instructions actually mention this, that would be helpful.
    I'm still dirty about it.... Good news though, at least my flywheel issues have been sorted.
    Cheers Rod
  16. The Following User Says Thank You to Rocket55 For This Useful Post:
    Bloodyaussie (19th October 2015)
  17. #220
    Sydney
    Turbo came out this afternoon to make way for a better item
    New v's old intake pipework
    I'll start on removing the injector pump after dinner.
    Cheers Rod
  18. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    BigRAWesty (24th October 2015), Hodge (24th October 2015)
