Results 1 to 10 of 15
Thread: Unbreakable Engine mounts - A step by step guide
Threaded View
  1. #2
    Advanced OLY's Avatar
    Step 1
    we start by taking the lower control arm and mark 15mm in from the lower part of the bush housing - do this at both ends
    use a thin cutoff wheel in the grinder to cut the bush ends off, i sat it loosly in the top of the vice and rotated the arm while holding the grinder still which gave me a nice square edge
    then you'll be left with this
    Step 2
    use a sharp blade to cut whats left of the rubber off the existing engine mounts as we need the plate that bolts to the chassis, i used a sharp kitchen knife but i thing a decent stanly knife is the go, you can throw away the top parts of the mount as the bottom plate is all we need
    cut the top and bottom off level and clean any remaining rubber off the base plates, i used one of these paint stripping disc's which work well but fly apart fairly quickly
    then you should be left with these
    Run Your Fingers Over My Patrol, I'll Run My Patrol Over Your Fingers!!
  2. The Following User Says Thank You to OLY For This Useful Post:
    AB (20th October 2015)
