Results 1 to 6 of 6
Thread: Smokey ZD 30
    Aug 2015
    Smokey ZD 30
    Hey guys i have a 2001 ZD30 GU with 321000km on the clock and in the last few weeks it seems to be running a bit "rich" and blowing a little bit more smoke than is usual, its running fine and oils and fluids are all good im just wondering whether the injectors need tending too or whether is something more sinister. I had it serviced 2 months ago and nothing showed up in the mechanics report, if it was a petrol engine i would say it needed a good tune up and and maybe the carby adjusted, any help would be appreciated..cheers Paul
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Could be anything from a dirty air cleaner to a warning of a disaster. Have you changed your fuel supplier?. I would check air and fuel filters first up.
  3. The Following User Says Thank You to 4bye4 For This Useful Post:
    godoggies (19th October 2015)
    177 Post(s)
    G'day mate. Try to clean the MAF sensor. That will be your cheap start to eliminating potential problem.
    Just Google cleaning ZD30 MAF or search this forum. A ton of info on it.
  5. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    dom14 (20th October 2015), godoggies (19th October 2015)
    Aug 2015
    Thanks guys will start with your suggestions..
    Do you know what boost you're getting??
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    Sep 2015
    Sydney
    I assume we are talking black smoke here?
    agree with everything above, to pick up on a bit more what threedogs said, as well as the well known boost issues with these engine, if you have a boost leak, you will also have black smoke, check your intercooler and all boost hoses.
  10. The Following 2 Users Say Thank You to abeeke For This Useful Post:
