Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: TD42 broken engine mount mod
    Did you take any pics...
    In his Frankenstein gq thread.
    Advanced OLY's Avatar
    I can take some, the first set I made I used the patrol lower arm bush, but the second set I made for a mate while helping do a TD conversion into an RB30 GQ, we made them so we didn't have to cut and weld the brackets on the chassis. in my opinion the second set with the Toyota bush came out a lot better than the first set with the Nissan bush
    Run Your Fingers Over My Patrol, I'll Run My Patrol Over Your Fingers!!
  3. The Following 2 Users Say Thank You to OLY For This Useful Post:
    BigRAWesty (18th October 2015), Bloodyaussie (18th October 2015)
  4. #13
    Ive seen them made using leaf spring poly bushes as well,
    was told though they are firm as with the nissan bush so
    be prepared for that.
  5. #14
    [QUOTE=threedogs;637525]Ive seen them made using leaf spring poly bushes as well,
    be prepared for that.[/
    QUOTE]
    yeah that's what I found as well, just not enough rubber in the bush to absorb engine vibration, same deal with the leaf spring bushes. that's why I used a surf rear control arm bush on the second set I made and with the larger bush the engine doesn't vibrate any more than standard
  6. The Following 2 Users Say Thank You to OLY For This Useful Post:
    BigRAWesty (18th October 2015), Robo (14th November 2015)
