Results 1 to 10 of 15
Thread: Camper Battery Charging
    Patrol Guru paulyg's Avatar
    Ballarat
    I have a 6 b&s cable with an Anderson plug on the draw bar of my camper going to a Ctek 250s Dual dc to dc charger, which then goes to my 2 100ah battery's in my camper.
    I plugged my 250 watt solar panel to this Anderson plug, after I bypassed the mppt controller, But I don't think it charges as quickly as it does using the panels own controller.
    I would like to use the panels own controller and connect directly to the battery's, But I don't really want to run another lead and Anderson plug.
    Can i do this? perhaps through a relay and switch between the different inputs?
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
    Uuummm... something is odd in your post.
    Do you have the Anderson Plug connected to the "Alternator In" or the "Solar In" of the D250S?
    also...
    What is the brand/model/part # of the Solar Controller?
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (17th October 2015)
    Ballarat
    Thanks evil, the lead is normally connected to the Alternator In terminal when connected to the Troll.
    I had been camping for a few days, so i moved the lead over to the solar input terminal, so i could use the solar panel to charge the battery's.
    I don't now what brand the Solar Controller is, it came with the panel.
    Quote Originally Posted by paulyg View Post
    Why do you want to use the panels controller? The ctek will work more efficient than the panels controller. Plus you should need to move the lead over to the solar input. Have one lead always connected to the solar input, for you panels, and the other input from the car.
    Pretty sure there is no need to change from alternator to solar.. that's so you you can simply have 2 sources plugged in at once and the unit will pick the best source.
    If you have it on the alternator but unplug car and plug in solar then that's the only source so it'll select that input.
    The charger on the pannel more than likely isn't an mppt charger. So that's probably why it seems quicker.
    I'd say bypass the pannel mppt and go the ctek..
    But don't bother changing alternater to solar. Just leave it on whatever pin and plug in whatever the charge device..
    Sweet... that makes sense now.
    OK, the Ctek is a pretty good Solar Controller and should have functioned quite well with the panels connected to it.
    Certainly it should have equal or close to the same performance as the Panel Controller all things being equal.
    To do what you are thinking would be reasonably easy and indeed there are a few different ways.
    The object is to bypass the Ctek so simplest one... Get a Changeover Relay (5 pin) rated to at least 40 amps and a mounting socket
    Remove the Camper Battery +ve from the Ctek and connect it to Relay pin 30 (common)
    - also note there will be two wires on this terminal when you finish
    Connect the Ctek Service Battery +ve to Relay Pin 87A (normally closed)
    - this means the Ctek will charge the Service battery as normal if the bypass switch is "OFF"
    Connect Relay Pin 85 to Ctek -ve or Camper Battery -ve or earth if the camper is earthed)
    - switching wire so light gauge is fine
    Connect a wire of 12 AWG or heavier from Ctek Alternator Battery +ve to Relay Pin 87 (normally open)
    - this is the wire that will carry the Solar Panel charging current bypassing the Ctek when the switch is "ON"
    Connect a switching wire from Relay Pin 30 via a switch to Relay Pin 86 (relay coil +ve)
    - this is the wire that will energise the relay when the switch is thrown thus bypassing the Ctek
    I would put a 25 amp fuse in the 12 AWG "bypass" wire just in case you forget and hook up the vehicle with the bypass energised
    A lot of work just to save adding an extra lead i reckon. I'd just run two sets of leads together in the one sheath, or convolute tubing and have two anderson plugs and just have them marked as Solar and car.
    less that could go wrong....
    Mudski and westy replied while I was dicking around but as per my post I agree with them that the Ctek should be goodo as a Solar Controller.
    You will need to connect the panels to the Solar input tho because that is where the MPPT Controller lives and it is not on the Alt terminal
    If you want to use 1 Anderson plug for both Alt and Solar via the Ctek controller then...
    Remove the Alt +ve from the Ctek and connect it to Relay pin 30 (common)
    Connect the Ctek Alt +ve to Relay Pin 87A (normally closed)
    - this means the Ctek will see the Vehicle Alt as normal if the bypass switch is "OFF"
    Connect a wire of 12 AWG or heavier from Ctek Solar +ve to Relay Pin 87 (normally open)
    - this is the wire that will carry the Solar Panel current to the Ctek when the switch is "ON"
    - this is the wire that will energise the relay when the switch is thrown thus moving the Ctek input from "Alt +ve" (pin 87A) to "Solar +ve" (pin 87)
    Don't balls it up tho or you may blow the Solar
    Me?... I agree with Mudski and I would just have two 50 amp Andersons or 75 Amp powerpoles and use the Ctek as manuf designed it
  10. #9
    Ballarat
    Strange thing is when i have the solar panel going through its mppt controller and connected to the Trolls 2nd battery i could see up to 13.6 volts on the volt gauge i have on the second battery.
    When i had the panel connected to the ctek in the camper with out going through the panels controller, the highest voltage i saw was 12.9.
    Maybe the panel voltage without the controller goes to high for the ctek, the ctek max voltage is 22 volts and the panel max voltage without the controller is 21.99.
  11. #10
    Uummmm... if I read that right you had a reading on one battery (in the Trol) 13.6 and a reading on another larger battery bank (in the Camper) 12.9... yeah?
    I would suggest all that means is that the Camper Battery Bank (which is way bigger than the Patrol so will load up more) was at a slightly lower SOC than the Aux Battery in the Trol
    IE everything is working as it should and you mistakenly compared apples to oranges (I could be wrong tho)
    To be sure I would use the same voltmeter for both tests and hook the panels via the Ctek to the Camper Bankand check the reading and then the panels via the Controller to the Camper Bank and check the reading again
