Yes, it certainly can by the Crank Pos sensor... amongst a heap of other things.
If the ECU thinks it is dodgy and throwing that code then you will need to sort that out anyway.
Keep in mind that if something is working, no matter how complicated the system, it is unusual to get multiple failures all at once.
I would try a new Crank Sensor and go from there
