Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: What is the redline for a TD42?
    Mar 2013
    What is the redline for a TD42? I have a 2000 GU which had a heart transplant being a 1990 silver top turbo, as the truck was originally a 3.0 ZD and still has all the original guages would like to know where I can safely rev it to... Also is it normal for it to blow smoke when I hit the pedal and it boosts up to 12PSI?
    Patrol Guru Rocket55's Avatar
    Sydney
    Don't know, mine won't really rev over 3,000rpm on the road... Think it went to 3,200rpm once.
    Cheers Rod
    My Build 2005 TD42TI
    Mar 2013
    Mine not a Ti so doesn't have any electric's controlling the motor...Just took it for a run and ran it to max boost, then I notice the boost starts to drop away is that normal?
    Should have taken a look at the tacho while I was at it, just wanted to see what it could/ would do...
    22 Post(s)
    I have seen 4200 in mine
    96 GQ coil/Cab
    08 G6eT
  5. #5
    22 Post(s)
    You dont have over revving as such, they are a mechanically governed pump. Once the governor takes over it wont rev any more
    96 GQ coil/Cab
    08 G6eT
  6. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    SKID (7th October 2015)
    Sydney
    Thanks Benny, didn't know that.
    I'm hoping mine will be capable of seeing 4,200 soon.
    Cheers Rod
    Quote Originally Posted by Rocket55 View Post
    Thats interesting. I turn mine to 4200-4500 each time I drive it. My redline on my dash is at 4500.
    Sydney
    Wow, yours must go better than mine, I couldn't be bothered waiting for it to rev that high
    Cheers Rod
  10. #9
    177 Post(s)
    Rodney you mentioned your s won't go above 3000-3200. How is it different to mine as I can easily drag a gear out to 3500-4000 range on road.
    Will it free rev to 4000rpm?
