Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Dilemma. Turbo or gu diffs
    So wifie have given the ok to upgrade the diffs to gu diffs.. yay.
    Found a nice set close by from a 2.8 so running (to the best of our knowledge) 4.6 diffs.
    Got 164 thou on them. Only bits missing are the front rotors..
    But. Should I get it turbo'd? I've been told I'd loose my nuts but I think it could be worth the risk lol.
    Cost is about both the same. Diffs will need rims and tyres.
    Turbo will need exhaust and gauges, intercooler etc.
    So I'm still not sure about the turbo. It's original driveline and clutch. 520 thou on the old girl now, a bit worried about it to be honest.
    Diffs will off set the 33's and a bit so will make towing the new van nice, better brakes, stronger diffs and gives the option of 35's if I want 😆
    What are people's thoughts??
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    well, is it going to be used for towing
    or
    playing
    if towing, you will know what the best option will be, as your driving it
    if its keeping up with traffic, and semi's are not overtaking you in 2nd gear..................
    its the old question of having 2 sets of tyres
    one for on road use
    one for playing off road
    what to do............................
    me.....? I'd go turbo & intercooler, see how it tows then
    if it needs better gearing, then try that
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Aren't 2.8 diffs smaller? Like physical size smaller then a td4.2/the 4.5/zd30 diffs
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    You'll need these for your diffs,
    cant source a TD at the wreckers to buy bits off
    http://www.ebay.com.au/itm/171641250...%3AMEBIDX%3AIT
  5. #5
    Quote Originally Posted by lhurley View Post
    No same size. The rear has a smaller pinion flange but that is easily swapped.
  6. #6
    Gu diffs are also wider so you may need to look at increase flare width. You will also require a drag link with 2 different ends in it as the gq ones are slightly different.
    Apart from the brake upgrade do you do anything that would really require the extra strength/weight of gu diffs?
    If its mainly a tourer then it should be an easy choice.
  7. #7
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Unless you're breaking your GQ diffs go the turbo best mod I've made to my truck.
    I turbocharged mine at 500k should have done it as soon as I bought it, pleasure to drive now
  8. The Following User Says Thank You to liftlid For This Useful Post:
    threedogs (3rd October 2015)
    Quote Originally Posted by liftlid View Post
    Doubt I'll ever break a gq cv. And the extra track is a bonus.
    Main reason for looking at them is there only 164k old, and will be solid brake upgrade. As well as off set the 33's so I'll gain a bit more due to going to a 4.6 and bypassing 4.3's
    As before. Clutch is my worry with turbo. As well as other things like temps, turbo quality etc. Only have around $1500, not $5000
    I dont think the GU diffs will advantageous for you, you could acheive the same result with wheels spacers [I know].
    I not sure how slugish a 4.2 is without a turbo but ppl Like Lift lid and Berrimah diesel fitted a turbo with 500K on
    the clock, Who knows you might get better fuel figures.
  11. #10
    178 Post(s)
    Seeings you’re asking I’d assume that you don’t really need either. If I were in your shoes I’d put the money away towards the big trip.
