Page 173 of 570 FirstFirst ... 171172173174175 ... LastLast
Results 1,721 to 1,730 of 5698
  1. #1721
    are you running an air tank with it?
    Just scroll down to the twin compressor
    http://www.arb.com.au/products/arb-compressors/
  2. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Hodge (30th September 2015), threedogs (30th September 2015)
  3. #1722
    177 Post(s)
    I have a single compressor, CKM12, but I have the tank and assembly from the twin portable one, will implement one day.
    My UHF Icom 440 extension for the mike arrived, now i can mount it on the passenger side
    1.8mtr long
  5. #1724
    I'll be making my sliders air tanks with outlets in each corner
    I've heard that's illegal... do you know if that's true?
  7. #1726
    Can't see how it's any different to an air tank??
    compressed air is a no no in case of collision. Better off buying a tested tank and bolting it to the chassis rail.
    Had that idea years ago and was warned off it , ended up making the side steps into water tank instead even with
    76 x 50 RHS by 1.8 mt long,,,not much water,
    how are you going to test them , and what happens if it goes pear shaped
  9. #1728
    Compressed air test.
    But it's my bus so I'll take that risk.
    They won't be pressurized most the time anyway, only when needed.
    Same as you don't run the air compressor all the time..
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Stropp (30th September 2015)
  11. #1729
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Compressed air test. But it's my bus so I'll take that risk. They won't be pressurized most the time anyway, only when needed. Same as you don't run the air compressor all the time..
    Do you have any pressure tickets? Not questioning your welding, just saying that if you do I see absolutely no reason why it could be called illegal.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  12. The Following User Says Thank You to Punderhead For This Useful Post:
    BigRAWesty (1st October 2015)
  13. #1730
    Quote Originally Posted by Punderhead View Post
    Sure do.
    Thus why I'm not to worried by it.
    Stick and tig in plate and 6G pipe (Which covers every position)
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Punderhead (1st October 2015)
