Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 70
Thread: TD42 high performance water pump feedback
    177 Post(s)
    Melba hwy up to Kinglake turn off, cracker of a test hill!
    This is the one heading north just before kinglake - healsville road ???
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Just took the camper back to mattys and the drive is up the calder with a number of big hills. The car did not go above 88 degrees and i travel the road semi often so this is one road i have a good idea of temps... normally without a trailer i get well into the high 90's on one of the really long hills so this is a massive difference. The recovery time is also much faster. The next hill the check is at ab's place. ..he knows the one.
    Which pump did you get?
  3. #23
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by liftlid View Post
    Try reading the thread. .... bone head
  4. #24
    Here are the pics all together including the gmb pump that i took out of my car.
    Gmb $140
    Attachment 61504
    Patrolapart $250 exchange
    Attachment 61505
    Jpc $480
    Attachment 61506
    Geeze it's chalk and cheese hey.
    You definitely get what you pay for.
    Good to see its working to.
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Bloodyaussie (24th September 2015)
  6. #25
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Gmb $140
    Attachment 61504
    Attachment 61505
    Jpc $480
    Attachment 61506
    I had that top one............
    was replaced with one that looks like N#2
    but DAYAM, I'm loving the look of N#3
    have to go check my money tree, and shake the leaves a bit to see if any falls out................
  7. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    BigRAWesty (24th September 2015), Bloodyaussie (24th September 2015)
  8. #26
    Nov 2010
    6 Post(s)
    Thanks for nothing
  9. #27
    6 Post(s)
    Quote Originally Posted by Bigcol View Post
    Most of the main customers come from the top end of WA, NT and places like that.
  10. #28
    Those other 2 look to me having seen john bennet water pumps
    will create a lot of cavitation, The one BA has is the bee's knees and well worth the $$$
    be it bit costly.
    Is there a bleed screw on the back of the head on these 4.2's for air
  11. #29
    6 Post(s)
    Ok here is another update.
    I have just spent 2 days traveling the local region with some big hills and much warmer weather plus at one point was towing more than a tonne of wood on winding country roads.
    I also climbed the hill near ab's place and everything has worked brilliantly.
    The hottest it got was 91 but besides the big improvement on temps was the way it recovers after the big hills.. the temps come back down so fast and do not linger in the higher temps long at all.
    I'll keep up the updates.
  12. #30
    Advanced OLY's Avatar
    good work mate, thanks for posting up your results. very helpful!!
    Run Your Fingers Over My Patrol, I'll Run My Patrol Over Your Fingers!!
  13. The Following User Says Thank You to OLY For This Useful Post:
    Bloodyaussie (18th October 2015)
