Page 549 of 1057 FirstFirst ... 547548549550551 ... LastLast
Results 5,481 to 5,490 of 10566
  1. #5481
    Quote Originally Posted by AJTich View Post
    Only had 17 days...but still had time to check so much out... Work next week..:-(
    Bloody work, always gets in the way.
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    AJTich (19th September 2015)
  3. #5482
    Pitb but finally drilled and wired up my DRLs. they are switched through a negitive earth.
    they are 9 watt bulls eye, I have permission from Clubby8 lol, they are 100mm apart,
    I will also be wiring a flat cob light into the system to illuminate the winch spool.
    All led so little power draw.
    Highly recommend these Cob leds for any lighting you may have
  4. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    AJTich (19th September 2015), Majestic (19th September 2015), Stropp (19th September 2015)
  5. #5483
    Expert Majestic's Avatar
    Oct 2014
    Central West NSW
    So do they turn off when the headlights are turned on or do they remain on even at night?
    I tried wiring some up a while back but I had no luck, I'm not sure if it was the wiring harness or not.
    Owner of 1984 SD33T MK Patrol
    Owner of 1989 TD42 GQ Patrol
    Previous Owner of a 1988 TB42 DA Maverick
  6. #5484
    That's starting to look like a muster truck.
    Planning a few B&s parties are ya td
  7. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    taslucas (19th September 2015), Winnie (19th September 2015), Woof (19th September 2015)
  8. #5485
    Quote Originally Posted by Majestic View Post
    they are wired so I manually switch them off bummer but was all I had here.
    My sons an Auto lec so Ill ask if he can wire them through a relay to turn off when lights are on
    Majestic (24th September 2015)
  10. #5486
    Got around to fitting a boost adaptor plate , that fits under the OE sensor.
    Took about 2 mins and looks very neat, was it worth $50 not sure but saves you drilling
    or soldering on any bungs.
    My old teflon one broke and I cant see how,boost was all over the place.
    Hopefully this boost plate adaptor will fix that. it even came with spacers for the engine cover
    but I dont have mine fitted. Highly recommend
    Weather still cold as a frog here today
    http://www.ebay.com.au/itm/Nissan-Pa...item3d00062dd3
  11. #5487
    Washed it. Lol
    drove it to work after 3 weeks of it sitting on the front yard looking all lonely and forlorn........... I should really get cracking with fitting the new suspension
  13. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    BigRAWesty (24th September 2015), Stropp (24th September 2015)
  14. #5489
    Expert Dman2603's Avatar
    Mar 2015
    Perth SOR
    Yes you should!! The joys of having a company car! Eh
    How were the eyes this morning?
    2006 GU IV ST MAN 3.0TD - UHF, Boost & EGT Gauges, NADS, Pro Vent 200, Snorkel, Tigged IC, 2" Lift, Dual Battery System & Still lots to come!
    Got a Patrol in WA CLICK HERE - Just Go There!
  15. #5490
    Quote Originally Posted by Dman2603 View Post
    they've been worse
