Results 1 to 10 of 17
Thread: N/A TD42 to Turbo
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    N/A TD42 to Turbo
    Hi all can anyone help with the location of the water return from the turbo unit, the oil pickup is located at the engine mount, but there dosen't appear to be drilling for the water?
    Quote Originally Posted by Pezzer View Post
    <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=61168"/><img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=61169"/> Hi all can anyone help with the location of the water return from the turbo unit, the oil pickup is located at the engine mount, but there dosen't appear to be drilling for the water?
    further to the right at the bottom of your first pic. Hard to see on this broken phone screen.
    It's not in the pic though.
    Have a good look at the back bottom left hand side of your block
  3. The Following User Says Thank You to AB For This Useful Post:
    Pezzer (9th September 2015)
    Expert ashmccormick's Avatar
    Jul 2015
    North Brisbane
    Hey mate, I think you can use the block coolant drain plug, someone please correct me if this is wrong!?
    Its a 12mm bolt thats sat right up behind that fitting that is on the right hand side of the block halfway up. Prick of a thing to get at if the engine is in.
    GQ Patrol, TD42 NA, 33's, Snorkel, 2" inch lift, Dual Batteries, Roof Rack, Awning... Many more to come
    Jun 2013
    Gold Coast
    020.JPG Hi Ash is this the bolt...
  6. The Following User Says Thank You to Pezzer For This Useful Post:
    AB (9th September 2015)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Yes, that's the drain plug for the block. It's 1/4 BSPT thread.
    Your other option is to put T pieces in your 2 heater hoses.
    Factory turbo engine has these fittings
    John
  8. The Following User Says Thank You to jff45 For This Useful Post:
  9. #6
    Jul 2015
    North Brisbane
    Yeh mate thats the one! easier than T-peicing heater hose I reckon. Thats what ill be using when I get time to turbo my mighty TD42!
  10. #7
    Jun 2013
    Gold Coast
    Cool
    Yes ok I think I will utilize this stabbing and plumb up to it, so now its just the water pickup line where to afix to then Im sorted for the moment. Hope someone buys my low mileage TB42E.lol
  11. #8
    Water will come from the coolant drain plug. You can put the return in the thermostat housing using a t where the heater hose returns.
  12. The Following User Says Thank You to nissannewby For This Useful Post:
  13. #9
    Jun 2013
    Gold Coast
    Cool
  14. #10
    Morayfield, QLD
    What is low mileage? I still have my TB45E engine in the shed, it's only done 136k kms. They're not worth a lot..
    John
