Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: RE5R05A - Anyone able to clarify -" If you have a trans fault replace the trans?"
    Expert SpecialDave's Avatar
    Apr 2015
    Greensborough / sunshine / Aspendale. Kind of homeless at the mo
    So spent about an hour under the old girl, in the cold, in the nearest national park some didn't p off the neighbours with her running and the occasional rev.
    Fluid is fine - no evidence of burning or coolant contamination.
    So I had my fav long screw driver stuck to my ear most of the time listening time internals and the noise is 100% from the bell end... It's right at the mating surface - and the noise has gone from a chatter to a matalic rattle as if you had a piece of stainless on top of an anvil and went over a fair whack of ripples...still predominately when in gear.
    No slipping as such but power loss for sure.
    02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
  2. #12
    I think i did read somewhere of the flex plate failing. Was on this forum I'm sure. There was a pic of the plate that had totally destroyed itself.
  3. #13
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    When you checked the fluid, did you check it off the dip stick or off the drain plug?
    If i can remember correctly my auto had a similar sound, metally rattley kind of sound, and it was the Torque Converter. The internal bearing collapsed. Check the drain plug for excess metal shavings.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  4. The Following User Says Thank You to lhurley For This Useful Post:
    SpecialDave (2nd September 2015)
  5. #14
    Apr 2015
    Last night dipper but have checked drain a week ago and found some metal
  6. #15
    Apr 2015
    Quote Originally Posted by lhurley View Post
    Can I enquire as to your repair?
    Diy or mechanic and if the later approx co$t!
    Dg
  7. #16
    Oct 2011
    I had it done at a shop as it actually broke down. Reason being all the bits of torque converter blocked the cooler and melted everything.
    Had I gotten it rebuilt before melting everything, would of been about 2k. In the end it cost me $4300.
    Not saying that yours will end up being like that, but they aren't cheap.
    How much metal was on the plug? Would your say it was a lot or seemed normal? Mine has more then expected before it died.
  8. The Following User Says Thank You to lhurley For This Useful Post:
    SpecialDave (3rd September 2015)
  9. #17
    Apr 2015
    Very slightly more - looks like tranny coming off and the wallet getting emptied!
  10. #18
    Oct 2011
    Tbh it's cheaper to get it properly fixed before it destroyes itself.
    Could just put a wrecker box in in the mean time until funds allow but then you are running the risk that it's in sh!tty condition.
  11. The Following User Says Thank You to lhurley For This Useful Post:
