Page 16 of 101 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 1003
Thread: Hodge's new 4.2
  1. #151
    Very pricey. I am looking at alternative. I'm a fan of numerical readings , but not much out there...
    Have a look at gloshift as well. They do a tri gauge with boost, water and oil. The boost is analogue while the water and oil are digital readout.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (2nd September 2015)
  3. #152
    177 Post(s)
    Will do my keeping my options opened. Just reading some reviews and a lot of redarc ones people are having issues with accuracy. Don't know wherether its the sender side of things or the gauge ...
    177 Post(s)
    Does this canister have a certain polarity ?? Can I swap these hoses around ? Would make a perfect fit. Lol
    177 Post(s)
    Reason I asked is if I could move that canister to the other side (compressor) side, I could use that space between the canister bracket and the battery tray/coolant overflow for mounting the BCDC , fuses etc... But to spin the canister around and mount it nicely I'd have to swap the hoses...
    177 Post(s)
    You can move the canister to where ever you want. As long as the hose are on the same way. Notice that top hose with the arrow too.
    Hodge (6th September 2015)
  9. #157
    177 Post(s)
    Damn! Didn't notice that arrow. I guess it has to be a certain way. I'll think of a way. Cheers mate.
    I had the canister on the zd in a different spot. I just manipulated the steel pipes carefully.
  11. #159
    177 Post(s)
    So stupid question, diesel doesn't flow through those, it's just the fumes? So if I disconnect a hose fuel won't be gushing out ?
    I can't remember having one of these on the CRD so don't know much about it.
    Patrol Guru Rocket55's Avatar
    Sydney
    It's a vacuum canister isn't it, to give more volume of vacuum (haha how's that for an oxymoron) for the brake and clutch booster???
    Cheers Rod
    My Build 2005 TD42TI
  13. The Following User Says Thank You to Rocket55 For This Useful Post:
