Page 624 of 1666 FirstFirst ... 622623624625626 ... LastLast
Results 6,231 to 6,240 of 16657
  1. #6231
    22 Post(s)
    Though ZD30 were black plastic Mudskis is Ally
    Ahh I missed that.. but yes it has an ally lid, but still a zd/td airbox
    96 GQ coil/Cab
    08 G6eT
  2. #6232
    476 Post(s)
    No its the oem air box with the high flow lid on it. It was what i had before with the zd.
  3. #6233
    Ahh righteo, cheers for that
  4. #6234
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Crap neighbors with there smelly, screaming devil kids are moving out from a unit upstairs.... Happy days!
    2003 GU SIII Auto Grenade. All the goodies.
  5. The Following User Says Thank You to Softy For This Useful Post:
    Irish (29th August 2015)
  6. #6235
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Wowsers! A few drops would have fallen to fill that... Heater hoses will take a a couple of hours Irish. Unless you drink beer with it, then its one rotation of the screw driver to undo the hose clamps to every mouthful...
    this is the most sensible post I have ever seen!!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  7. #6236
    Half price AA & AAA Batteries at Coles. Stock up
  8. #6237
    $400 to get all rust removed and done up to primer stage.
    I'm planning on a re spray during summer.
    Sent from my SM-G800Y using Tapatalk
    That's not cheap! I buy them by the thousands from Eveready =)
  10. #6239
    BiPolar Fool BSRT.Beast's Avatar
    Apr 2015
    Keysborough
    4 Post(s)
    finally getting my headlights sorted
  11. The Following User Says Thank You to BSRT.Beast For This Useful Post:
    threedogs (30th August 2015)
  12. #6240
    22 Post(s)
    Yes it has a roller bearing gtx3071 turbo. Does sound pretty good. As for the inlet Mat, i haven't looked mate. I assume its 3inch.
    Have you thought about replacing the airbox with a higher flow 4 inch air box? Personally I think it should be changed sooner rather than later, the gtx 71mm compressor moves an immence amount of air. A huge amount more than the zd airbox can flow. You'll find that the turbo is working so hard for its air through that airbox that it is wasting energy in order to get it. Having the 4 inch airbox and pipe from snorkle to turbo (remember the 3071 has a 4 in intake) will help. As a result you'll see an increase in engine responce. Note that your torque climbes quickly on that graph (good) to a high amount (even better) but drops nearly as quick as it climbs (not so good). A big contributor to that sharp drop off is the intake. Changing it will help to level it out and extend that torque band, there are many other factors too, but I wont go into them now as I'll let your boner wear off about this motor
    This is by no means critisism of your setup. I have had a big garrett on a 42 for a few years now. You, a few days. There are alot of things that need to be done to compliment the few things they do really really well
    96 GQ coil/Cab
    08 G6eT
