Results 1 to 10 of 10
Thread: Disk Brake Pad uneven wear
    Jul 2014
    Hi there,
    I have been doing some maintenance on my 4by.
    I have one brake caliper on the rear where the pads have much different amounts of wear than each other.
    Why is it that on one brake caliper I have one pad that is 5mm thick and the other pad is only 2mm thick?
    Does the caliper get stuck or something, all the others front and rear have about the same wear.
    It is so annoying, now I have to purchase a full set of pads for the rear disk brakes on my 4by.
    Thanks,
    Neil.
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    never seen that before. Might be worth wile speaking to a brake specialist. hope the rotor is not warped.
  3. The Following User Says Thank You to blocko05 For This Useful Post:
    Patrol 1993 (23rd August 2015)
    Thomastown, Melbourne
    6 Post(s)
    Sticking sliders on your calipers mate.. not uncommon for a 4wd playing in mud and stuff.. make sure the rubbers are in good condition and not letting mud in.
  5. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    one of the callipers could be sticking or the port in the master could be blocked, (seen the blocked port on falcons a bit when the fluid isn't changed often but usually thats on the front)
    make sure the callipers slide easy. and sit even over the rotor.
  7. The Following User Says Thank You to garett For This Useful Post:
  8. #5
    Yep as above.
    My wife's commo had the same problem.
  9. The Following User Says Thank You to jay see For This Useful Post:
  10. #6
    Legendary dom14's Avatar
    38 Post(s)
    I had the same problem on my RB30. It was caused by a jammed slide pin. It needed fair bit work to fix it. I had to rebuild it. Slide pin wasn't easy to pull out either. You need a minor rebuild kit, which usually includes the piston boot, slide pin boots. You also need caliper grease, which usually come in little sachets. I used valve grinding paste to polish the slide pin and the pin bore. It was a good exercise, but would've been cheaper to get a used caliper from a wrecker or fleabay. Your's doesn't sound like completely jammed, so, it might be a good idea to pull it out, clean and lube it right now.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
  12. #7
    Were all pads changed at the same time, that you know of.
    If not re-co the caliphers so they slide freely
  13. The Following User Says Thank You to threedogs For This Useful Post:
    Patrol 1993 (25th August 2015)
  14. #8
    Jul 2014
    Hey threedogs.
    By the look of the pads the whole lot, front and back were done at the same time.
    I decided to do front and back this time as well.
    Hey Dom14,
    I took the calipers right off and cleaned the slide pin boots out with a small brush and turps and re applied new grease.
    I will see how it goes.
    Thanks Neil.
  15. #9
    Expert billyj's Avatar
    gordon
    just so you know mate, you should be using rubber grease on all brake slide pins
  16. #10
    38 Post(s)
    It's a blue colour grease that comes in little sachets, right?
    Cheetah Outreach
