Results 1 to 8 of 8
Thread: Dawes needle and valve fitting.
    Aug 2015
    Lower Portland
    So I got my dawes kit from northern 4x4 yesterday. I fitted this arvo following their instructions, which I might say are the best instructions I've ever had to follow. Only took about half an hour and let me tell you this is not the same came car. My boost gauge is smooth all the way to 15 psi. The engine is not working as hard. EGT's are a little lower at cruising.
    08 gu. Winch bar. Dominator winch, roof cage, 32" and 22" light bar, 3" inch exhaust. 33 " tyres, 2" flexicoils. Oricom uhf boost and egt gauges snorkel.tig welded intercooler. Dawes and needle valve. And 2 baby seats.
  2. The Following 3 Users Say Thank You to Ex telstra truck For This Useful Post:
    Hodge (22nd August 2015), mudski (22nd August 2015), threedogs (23rd August 2015)
    177 Post(s)
    Good to hear mate. Another successful NADS story.
    Ex telstra truck (22nd August 2015)
    Aug 2015
    Lower Portland
    Cheers defiantly put a big smile on face.
    476 Post(s)
    Good to see my dribble is understandable. Anything you think i could do to make the instructions better? Its a good feeling when you do something yourself and you really notice the change. I've lost count on how many emails and messages i get on eBay saying that using these valves is a waste of time and money and don't do a thing for performance, or anything. The results speak for themselves i say.
  8. #5
    Aug 2015
    Lower Portland
    I found the instructions really simple to follow. I read it a couple of times first. The kit I got is by far the best mod I've done to the car. It is avoid feeling when a plan comes together. I try to do a lot my self but being a crd engine their is only so much I can do. But cheers mate very pleased and impressed.
  9. The Following User Says Thank You to Ex telstra truck For This Useful Post:
  10. #6
    Advanced morton2478's Avatar
    Mar 2015
    I must agree mudskis directions for fitting the nads are very straight forward and easy to follow and i also agree with ex telstra truck about the boost being so much smoother after fitting. i thought the big girl run well prior to fitting all the bits and pieces but since i have fitted the new intercooler and fan she's goin even better now so next on the list will be a 3" exhaust
  11. The Following User Says Thank You to morton2478 For This Useful Post:
    Ex telstra truck (23rd August 2015)
  12. #7
    476 Post(s)
    You wait until you fit the pipe. It will be so different again.
  13. #8
    Aug 2015
    Lower Portland
    Yeah my next mod will be the intercooler I've got a full 3" exhaust with a stainless steel cat and a small resonator. My boost was all over the shop till I did the Dawes kit. Such a different car.
