Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: I didn't think that I was that strong.
    This is what happened when I tightened up the screws for the auto hub.
    How soon should a be changed.
    Funny thing was it didn't seem that it was all that tight
    476 Post(s)
    Should be changed asap mate. I seen you. Your name should be Arnold.
    jay see (20th August 2015)
    Whoah! That is unreal. Can't believe it broke like that!
    I would definitely change it before you put it into 4wd next!
  5. The Following User Says Thank You to Winnie For This Useful Post:
    84 Post(s)
    Forty foot pounds.
    Not: "Do it up until
    it snaps then back it
    off half a turn!!!"
  7. The Following 4 Users Say Thank You to mudnut For This Useful Post:
    ashmccormick (20th August 2015), dom14 (21st August 2015), jay see (20th August 2015), Punderhead (20th August 2015)
  8. #5
    What about just 2wd on the road, shouldn't be a problem, right?
    How common is this to happen.
  9. #6
    Legendary happygu's Avatar
    It will be ok in 2wd ....
  10. The Following User Says Thank You to happygu For This Useful Post:
  11. #7
    176 Post(s)
    I fitted these to mine, not sure how much difference they make, but I imagine they spread the load a bit more than none at all.
    http://www.ebay.com.au/itm/Nissan-GQ...item1ea27ce122
  12. The Following User Says Thank You to Cuppa For This Useful Post:
  13. #8
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    I thought they would have at least some sort of a washer. You will probably find the alloy was already fatigued, and that was the final straw.
    I'd just upgrade to manual hubs to be honest.
    If the Hub is still sitting flush on its seat, I don't see a problem driving in 2wd, just make sure you're not leaking any grease.
    Cheers!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  14. The Following User Says Thank You to Punderhead For This Useful Post:
  15. #9
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Must of had your wheties for breakfast.
    They may of already been weakened/damaged. Should be fine in 2wd for now. Change before you need 4wd drive though.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  16. The Following User Says Thank You to lhurley For This Useful Post:
  17. #10
    Thanks for the replies.
    Don't what to get a second hand pair, so what you you people recommend as a aftermarket type.
