Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Stalls after acceleration when dropping to idle
    Legendary dom14's Avatar
    38 Post(s)
    Your second carby doesn't has to be a Nikki.
    If you are going for a second new carby, I would go for a Webber or a Holly.
    Both available on fleabay, even cheaper than Nikki I reckon,& can yield lot more power with proper tuning.
    Check bumtree. I saw a guy selling a Holley 600 for an RB30 for $100 or so. He also has an RB30 carby with a manifold.
    Guy's in Perth. I wanted them, but he apparently won't post or separate the manifold & the carby.
    http://www.gumtree.com.au/s-ad/perth...rby/1083863545
    http://www.gumtree.com.au/s-ad/perth...old/1083862226
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. #22
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    from what i hear holley's arnt great for 4wd ing, on steep hills the tend to lean out too much. (just what i hear) if any one can tell me i'm wrong let me know, cos i will probably end up fixing up a couple land rovers (brother is a land rover fan)
    i'm a webber fan got one coming for my laser, v-tec is not going to save you
  3. The Following 2 Users Say Thank You to garett For This Useful Post:
    dom14 (18th August 2015), taslucas (19th August 2015)
  4. #23
    38 Post(s)
    Hey Garett,
    We poor bums can't afford Webbers. So, if you are ok with donating a one, I'm happy to help with your charity by taking it.
    BTW, by the looks of it, Webbers are hard to come by comparing to Holleys( I meant secondhands).
    If you find a one suitable for RB30, on fleabay or bumtree, pls let me know.
    Can't afford brand news atm, 'cos I've been spending too much on other mods.
    Cheetah Outreach
  5. #24
    38 Post(s)
    I've been advised, the below bumtree Holley carby is not suitable for RB30(too big)
    Cheetah Outreach
  6. #25
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Yep, from what I can find out, the 330 Holley designed for 4wds are good, (company in Queensland do them), but they are not cheap... I've also been warned they have mechanical secondaries and don't mind a sip of fuel or two, although that's just the usual blokes drinking beer round the fire talk.
    I have rebuilt and put webber 34ADM's from the 4.1 cross flow XE / XF falcon on a couple of different motors before, I put one on an old hard revving gemini, fuel usage was high but it made a TONNE of power!
    I'm still also toying with a fuel injection transplant from an R31 skyline or VL commodore, just dunno, I do like carb simplicity, but I would also like extra power for highway, even with removing the heater element thing, a bit more would be nice.
    I still think I'll go the rebuilt carb route, just want to make sure it's 100%, I hate reliability issues....
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  7. #26
    38 Post(s)
    You are not likely to get extra power by converting to EFI, but fuel economy will improve.
    Check with the link I gave you. $50 or less for a carby+ manifold+air snorkel pipe is a good deal if you can pick it up.
    Cheetah Outreach
  8. #27
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    This may seem simple but have you checked to see all the linkages are working free and smoothly? I'd suggest a good going over with wd40 and check to see if there's any detached springs.
    Hello from Under Down Under!
  9. #28
    Oct 2014
    WA
    Thanks mate, I've found it is often the simple things that get you! I've had the air cleaner assembly off and all the linkages are working perfectly. All the springs are attached and the electrical connections all seem ok :-)
  10. #29
    Aug 2011
    North West Tas
    56 Post(s)
    All good then. Any vacuum lines off or split?
  11. #30
    Oct 2014
    WA
    They all seem ok so far but a couple have hardened up with age so they'll be getting replaced this weekend, along with a few other maintenance things, and a couple of little improvements to my cargo area set up
