Page 15 of 19 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 187
Thread: Checking and cleaning MAF sensors
  1. #141
    Apr 2015
    i had a sleepless night thinking of major problems as the patrol was surging really bad yesyerday on acceleration over 2000rpm. i joined this site this morning and with the step by step instruction above , i have fixed the problem. cheers mate
  2. #142
    Aug 2015
    Perth
    and we live and learn. Just cleaned mine .it was manky.seems a bit more responsive but I have other issues to fix as well. Thanks for the tips though
    what does this switch do?
  3. #143
    Quote Originally Posted by watrolly View Post
    Some dis-connect the battery while they
    clean the Maf allowing the ECU to relearn/re-set
  4. #144
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Hi all. Is there any chance someone has a picture of the MAF in a 4.5L petrol. So I can see where it is located. Cheers.
  5. #145
    Aug 2015
    Redcliffe, QLD
    Don't know if this has already been discussed - if I don't have the proper bit to undo the screws holding the MAF sensor in, is there any reason why I can't just take out the section of pipe with the MAF in it and spray my CRC MAF cleaner on it? Or should I just buy the bit and stop being a tight**** (rhetorical question really)
    2004 GU III ST-L ZD30 5sp Manual
    Love that Leather
  6. #146
    Just buy the bit. Its way quicker this way and your less likely to stuff the plastic sections that hold the four nuts in place where you undo the bolts to separate the lid to housing.
    Gold GUIII (15th September 2015)
  8. #147
    Aug 2015
    Redcliffe, QLD
    Yeah, just got my lazy a** down to supercheap & bought one, can of MAF cleaner too. Bloody thing was spotless & looked brand new anyway. Oh well, now I know.
    Love that Leather
  9. #148
    Still need to do this.
    Will get around to it one day.
  10. #149
    Aug 2015
    Brisbane, Qld
    Thanks for the great instructions and which size bit to buy (T20). Did this on the weekend with no probs and disconnected the battery as well. Cleaner is not the cheapest thing to buy, but 30% off at repco for RACQ special def helped
    GU III 2001 Nissan Patrol 3.0L ; Tough Dog Suspension.
    To Do: 3" Exhaust replacement
  11. #150
    Expert bsteveo's Avatar
    Jun 2015
    Melbourne, VIC
    Is there much if any advantage to be gained by doing so?
