Results 1 to 9 of 9
Thread: keeping your distributor water tignt
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    Hi Guy,
    Just wanted to ask how has anyone been able to keep their distributor water tight. Some pics would be good as well. I just want to prep my Patrol for another west coast trip here in TAS.
    cheers
    Blocko
    I bought a TD42, sorted it right out......
    I have seen guys put it in a plastic bag or even a nitrile glove.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    blocko05 (16th August 2015)
    84 Post(s)
    I have plans to plumb in
    an air line and pressurise
    it to 1-2 psi using an air horn
    pump.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    i have seen a l/c with a hose into the dizzy from the air compressor next to it. dont know how effective it is but i dont need to. td42 :P every one tells me to wd40 it but again never tried it. not sure about it
  7. The Following User Says Thank You to garett For This Useful Post:
  8. #5
    Patrol Freak kevin07's Avatar
    georges hall
    pump.
    that sounds interesting
    13 y62 the beast that burbles
  9. The Following User Says Thank You to kevin07 For This Useful Post:
  10. #6
    Use a air horn compressor with a needle valve to adjust the amount of air you need.
    drill and tap a gland in the side of the dizzy, have a switch inside to activate before you enter
    a river , bog hole what ever, works a treat on my mate petrol Patrol ,highly recommend
  11. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    blocko05 (16th August 2015), mudnut (16th August 2015)
  12. #7
    84 Post(s)
    I keep forgetting I've
    got the ARB single
    pot compressor mounted
    under a passenger seat.
    I have already raised the
    inlet filter to the rear
    quarter panel trim.
    All I need is to get
    two T-pieces, a needle valve,
    a 12volt solenoid, a switch
    and some hose. I have
    already got the nipple
    fitted to the timing belt
    cover and the dissy cap
    has a nipple moulded into it.
    It will only have to
    barely pressurise
    the cap or it may
    stuff up the oil seal
    and cause a leak.
  13. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    blocko05 (16th August 2015), threedogs (16th August 2015)
  14. #8
    YYeah only needs a few pounds of air, Run one to the Dizzy the other to your winch
    Failing that a Safeway bag and a red rubber band from Aust post, very hi-tek
  15. The Following 2 Users Say Thank You to threedogs For This Useful Post:
  16. #9
    Apr 2015
    Hobart TAS
    Hi TD, do you by any chance have a pic of your mates set up. I would live to see it. Has he also sealed the cap to the distributor as well.
    thanks
