Results 1 to 10 of 12
Thread: Now would be a good time to...........................
    Now would be a great time to service your cooling system in time for summer.
    Maybe remove and clean the radiator, even get it rodded, some fresh hoses
    and new OE thermostat.
    Last thing you want is your camping trip spoiled.
    In fact a good time to go over the Patrol and find some things that may need attention.
    Dont forget to check your nuts too especially if you have a GU Y61
  2. The Following 4 Users Say Thank You to threedogs For This Useful Post:
    Hodge (9th August 2015), MudRunnerTD (9th August 2015), Sherro (17th August 2015), Woof (13th August 2015)
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Noticed earlier that my overflow tank has lost about 1cm since i looked at it the other week..... Hopefully nothing to bad is happening...
    2003 GU SIII Auto Grenade. All the goodies.
  4. The Following User Says Thank You to Softy For This Useful Post:
    threedogs (8th August 2015)
    Aug 2010
    adelaide
    what about checking those batteries / cleaning terminals /topping up the fluid in then if wet cell
    OH LEATHER IS NICE
  6. The Following User Says Thank You to my third 256 For This Useful Post:
    threedogs (9th August 2015)
  7. #4
    Jul 2015
    Scarborough, WA
    Now that the modern radiators have plastic caps is there anything we need to look out for?
  8. #5
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Can you elaborate on checking the nuts on the GU Y61? Trying to get my 1999 2.8 in order.
  9. #6
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by SiberianPatrol View Post
    Probably talking about wheel nuts. There has been a bit of discussion about wheels coming off or breaking if torqued incorrectly.
  10. The Following User Says Thank You to 4bye4 For This Useful Post:
    SiberianPatrol (13th August 2015)
  11. #7
    Quote Originally Posted by 00marshall View Post
    Yes a lot of dust/dirt will accumulate on the bottom of the radiator.
    Either remove and clean with a hose. If using a pressure washer
    go easy. You'll be surprised how much crud can get there
    If you own a GQ check the thermo fan for signs of cracking and becoming brittle
  12. The Following User Says Thank You to threedogs For This Useful Post:
    00marshall (14th August 2015)
  13. #8
    Expert ashmccormick's Avatar
    Jul 2015
    North Brisbane
    Great post threedogs! Just waiting for my new radiator to get delivered to give my cooling system a full overhaul! Especially since it's nearly build up season!
    Also worth installing some kind of aftermarket temp gauge/warning system as the old gq gauges aren't always very accurate. I use 2 different systems in my rig - engine watchdog, and an in hose gauge too
  14. #9
    Nov 2013
    QLD
    Good post. I noticed that my car is now heating up till 103ish under normal load. I already have a new radiator, viscous fan and thermostat but I get the impression that the thermostat is off. Time to replace that one
  15. #10
    Quote Originally Posted by dannypatrol View Post
    Replace with an OE unit only, After market seem to cause issues
