Results 1 to 10 of 17
Thread: No indicators AGAIN - Help
Threaded View
  1. #15
    Nov 2011
    Jimboomba
    Success..... I hope....due to intermittent nature of problem....I won't be sure for a while. Closer inspection of the float revealed a section of cable that had rubbed to bare wire where it disappears inside the frame of the float pretty close to the plug...where there is a lot of movement - as mentioned by Cuppa. Also found another place in danger of similar problem...so it has been sorted too. Thank-you all for your many suggestions. I will gradually replace standard lights with LED versions. And I now know that I need to add cable and plug inspections to my regular trailer maintenance. Thanks again.
  2. The Following 4 Users Say Thank You to Patrolee For This Useful Post:
    Bigcol (12th August 2015), Clunk (11th August 2015), Cuppa (11th August 2015), SpecialDave (11th August 2015)
