Page 16 of 46 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 456
Thread: Rockets Wagon
  1. #151
    Looking sweet! Your gear surround is quite different to mine?? Odd? Thought yours was an Auto by that surround?
  2. #152
    Patrol Guru Rocket55's Avatar
    Sydney
    Hmm.. The start of the thread has my 2010 CRD auto in it. About half way through I sold it and picked up a 4.2 manual. The surround with the two digital volt meters in it is from my CRD auto.
    Cheers Rod
    My Build 2005 TD42TI
  3. The Following User Says Thank You to Rocket55 For This Useful Post:
    MudRunnerTD (7th August 2015)
  4. #153
    Quote Originally Posted by Rocket55 View Post
    Ha! I went back two pages looking for it and did not go back far enough. Makes perfect sense.
  5. #154
    Sydney
    Couple of quick little jobs this afternoon. When whoever put the lift in they never installed the extended brake bias bracket
    So in one went.
    Couldn't feel any difference when driving it but at least now I know it's right.
    Cheers Rod
  6. #155
    Sydney
    Next came a pretty cool little mod, well I think so anyway. Converting the auto hubs to free wheeling hubs. This allows me to select L4 without being in 4wd and hence winding up the transmission and drive line. Perfect for reversing trailers
    Lock the hubs, Undo the 6 x 8mm cap screws and pull the hub off.
    Place the hub in the vice and pri out the locking ring. I found it really tight, but if I tried at a different place around the ring it popped out really easy. So give it a go in a few places and you'll find it pops out with minimal effort.
    This is what the hub looks like with the locking ring removed.
    This is both the locking rings (one from each hub) one is upside down one isn't.
    Now just put the hub back on and you're done. The whole process should take 10-15 minutes if that.
    Cheers Rod
  7. The Following 4 Users Say Thank You to Rocket55 For This Useful Post:
    Clunk (13th August 2015), Hodge (10th August 2015), MudRunnerTD (9th August 2015), mudski (9th August 2015)
  8. #156
    177 Post(s)
    Looking very nice mate. Saved your post for when I get my rig back. Will do this mod.
    Sydney
    It's a great little mod and it is really very simple and quick.
    Cheers Rod
  10. The Following User Says Thank You to Rocket55 For This Useful Post:
  11. #158
    177 Post(s)
    Rod, how is the Raslarr bar going so far? Any feedback on it. Saw one earlier today, and looked the goods. Definitely now considering one ...
    Sydney
    So far so good with it. I have noticed a creaking sound when I flex it up a little bit that I need to get to the bottom of. The reverse light seems to fluctuate in brightness while on. They do it simultaneously so I assume it's an earth issue as opposed to a bar issue. I need to run some power down the back for some other things so I'll put a relay in and pick up a solid positive and negative and see if that resolves it, I'm confident it will. All said and done I'm really happy with it and loving the auto opening mechanism for the swing away arm though.
    Cheers Rod
  13. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (13th August 2015)
  14. #160
    177 Post(s)
    Thanks for that mate. Good to hear some positive feedback. Might have a chat to them this weekends coming 4x4 show and see if there is any specials.
    Also fitting was fairly straight forward ? Just wraps around and utilizes existing tow bar captive threads and holes/bolts ?
